Does anyone know how to remove the "Headers" from RTVE Spain?
I have the:
LINK: https://www.rtve.es/play/videos/el-caso-cronica-de-sucesos/caso-cronica-sucesos-capitu...adero/5622506/
MPD: https://rtvedrmstaging.rtve.es/06/25/5622506/5622506_drm.mpd?idasset=5622506
PSSH: AAAAQ3Bzc2gBAAAA7e+LqXnWSs6jyCfc1R0h7QAAAAF0avF97D B9jUrIoqO0C+vsAAAADyIHNTYyMjUwNkjj3JWbBg==
LICENSE: https://3e6900a5.drm-widevine-licensing.axprod.net/AcquireLicense?AxDrmMessage=eyJhbGc...5eR2C6Zb6gTXH0
But when I put the pssh and the license it doesn't get the keys out. What are the headers? Thank you.
Results 1 to 12 of 12
no header need
[Attachment 75427 - Click to enlarge]
Code:--key 746af17dec307d8d4ac8a2a3b40bebec:e3b9d43588a614db02618df4ea20da3d
and why should we help you, when this is a Paid site you posted, this has been told so many times, don't you guys read the rules before posting? I guess not.
not when I went to it, it had a place to login and it wouldn't even play the stream, that is why I commented on it, and he did indeed post correct info, not sure why he couldn't use the free CDRM-Project site to pull the keys with the info he posted.
Well, something has changed, because with the website "https://cdrm-project.com/" I don't get the keys today.
LINK: https://www.rtve.es/play/videos/la-promesa/episodio-252/7036694/
MPD: https://rtvedrmstaging.rtve.es/94/66/7036694/7036694_drm.mpd?idasset=7036694
PSSH: AAAAOHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABgSEL6q6G yA68opKDudgQ74VL5I88aJmwY=
LICENSE: https://3e6900a5.drm-widevine-licensing.axprod.net/AcquireLicense -
Have you tried this website?
https://www.descargavideos.tv/
Just paste the video URL and select the first option to download. If there are subtitles, you will find it at the bottom.
Unfortunately this is limited only to 720p even if 1080p is available
Also the videos audio is only in Spanish even if there is original language for example in English or French -
you must add only x-axdrm-message in header
[Attachment 75601 - Click to enlarge]
Code:--key beaae86c80ebca29283b9d810ef854be:4b838b31d48767f3804d808355e74921
Code:N_m3u8DL-RE -M format=mkv --key beaae86c80ebca29283b9d810ef854be:4b838b31d48767f3804d808355e74921 "https://ztnr.rtve.es/ztnr/7036694.mpd" --save-name video
Videos from RTVE
By animaltracks in forum Video Streaming DownloadingReplies: 9Last Post: 6th Jun 2025, 01:47 -
Trying to download from RTVE Spain
By Garfield025 in forum Video Streaming DownloadingReplies: 7Last Post: 7th Oct 2023, 01:26 -
How to grab RTVE stream?
By pedrothelion in forum Video Streaming DownloadingReplies: 6Last Post: 14th Jul 2021, 07:23 -
Downloading subtitles from rtve.es
By AllisOne in forum SubtitleReplies: 6Last Post: 22nd Oct 2020, 12:19 -
downloading videos from rtve Espana
By Petra78 in forum Video Streaming DownloadingReplies: 1Last Post: 14th May 2020, 05:14
