I have a Sony kdl 40wd653 and have some programmes recorded via a usb stick but I would like to be able to play them on my laptop. I believe they won't because of the tv's encryption but is there away around this at all?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 9 of 9
Never heard of it but thanks, I wonder if it’s safe to download and I wonder if the free version will do what I want it to do!
ProgDVB doesn't decrypt recordings. It is definitely safe to download from VideoHelp's software section.
The pro version of ProgDVB is supposed to be able to record from the following sources.
- Internet TV and radio. (About 8000 channels.)
- DVB-S (satellite), DVB-S2, DVB-C (cable), DVB-T, DVB-T2, ATSC, ISDB-T (This requires an appropriate TV tuner card for your PC.)
- IPTV
- Kartina TV, Rodina TV, OTT Club, Shura TV, Sovok TV.
I can't tell for certain what kinds of limitations the free version has but it may be limited to Internet TV and radio.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
You are right. I got confused with recording from a satellite receiver that has AV out connectors.
I remember deleting all my recordings on my Sony TV few years back. It had a built in satellite receiver and I had the same problem that you have now. Bought VU+ receiver which is enigma 2 and doesn't encrypt the channels recordings.
Well if these recordings are really important to you and nothing else works, you could setup to record by playing to the TV, using a good quality camera or your mobile and a tripod. -
I looked at the manual for KDL-40WD653 (Sony UK) and in the specifications it says
Input/Output jacks
Antenna (aerial)/cable
75 ohm external terminal for VHF/UHF
Satellite antenna*1
Female F-Type Connector, 75 ohm. DiSEqC 1.0,
LNB 13 V/18 V & 22 kHz tone,
Single Cable Distribution EN50494.
AV
21-pin SCART connector (CENELEC standard)
including audio/video input, RGB input and TV
audio/video output
Your TV model might not have a SCART connector, but please check if it has and try to see if you can watch your recordings on a device that has AV input like a small TV.
The SCART connector makes recording to a VCR/DVD recorder possible.
Playing recovered .swf files from a ZOSI H265+ DVR -Recovered Files from HD
By WitsEnd in forum Video ConversionReplies: 1Last Post: 27th Jun 2022, 02:09 -
How to Decrypt M2TS files recorded from a Sony Brave Television ext. hdd
By busel in forum Video ConversionReplies: 10Last Post: 17th Sep 2020, 21:02 -
By busel in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 17th Sep 2020, 15:51 -
Some MOV Files Not Playing
By box-turtle in forum Newbie / General discussionsReplies: 17Last Post: 27th Jun 2020, 18:54 -
some mp3 files not playing
By Barry Ellin in forum Newbie / General discussionsReplies: 3Last Post: 5th Feb 2019, 10:45
