I digitized many of my old VHS/VHS-C tapes, than Video8 and Hi8. Everything ok that far. But as I came to the
newest tapes, the Digital8, I have problems with artefacts, I'll try to describe.
Capturing is mostly ok, but sometimes it comes to a kind of blocking, starting with some horizontal lines that are
freezing, and ending with 6 "stripes" of equal hight: the upper most stripe shows the normal video, next one the
"standing" blocking pixel, next one normal video and so on. The freezed lines don't go away after scene
changes, they disappear after a long while.
For better understanding I will upload a short sample video (half resulution, but errors are recognizable).
I think blocking is ok if there are problems with the tape (if there are not correctable),
but I don't understand, why they are partially frozen? And why so long, also when scene has already changed?
My used signal flow: Sony TRV330E PAL -> Firewire -> Sclive
Is it a known problem? And if yes: how to avoid it? I googled/searched different forums, but didn't find an answer.
Freezing lines means read error due to damaged tape or clogged heads. Each thick line is one track, 12 tracks per frame for "PAL" (6 tracks per field, recorded be one head), 10 tracks for "NTSC". So, it seems that one head is clogged.
Thanks for the fast reply! You answer also makes clear, why partly a "live" image can be seen.
ffmpeg h265 and banding / blocking artefacts
By marco000 in forum Video ConversionReplies: 3Last Post: 19th May 2023, 13:45 -
Capturing Digital8 using Sony DCR Firewire/IEEE 1394 port - scrambled image
By Colek in forum Capturing and VCRReplies: 22Last Post: 24th Aug 2021, 00:42 -
Best practices for capturing Video8/Hi8 tapes- Digital8 camera best or not?
By siphon in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 6Last Post: 12th Jun 2019, 07:32 -
Sony CCD-TRV Hi-8 XR vs. DCR-TRV Digital8 for Capturing 8mm/Hi-8?
By Duder_Me in forum Capturing and VCRReplies: 9Last Post: 6th Jun 2019, 13:12 -
MPC-HC Remaining time
By therock003 in forum Software PlayingReplies: 4Last Post: 26th Apr 2019, 23:16
