hi there, i have some old video file (video only, already detach audio file) but video is jerky (or choppy)
already tried to re-encoding with ffmpeg with this simply command:
but no luck. video is always with same problem (jerky)Code:ffmpeg -i video.mp4 -c:v libx264 -crf 23 -preset:v fast -y video_2.mp4
someone have right suggestion about this ?
here MediaInfo video details:
Code:General Complete name : C:\9435843.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom (isom/iso2/avc1/mp41) File size : 41.9 MiB Duration : 11 min 34 s Overall bit rate : 506 kb/s Frame rate : 7.868 FPS Writing application : Lavf60.18.100 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 11 min 34 s Source duration : 18 s 108 ms Bit rate : 505 kb/s Width : 586 pixels Height : 888 pixels Display aspect ratio : 0.660 Frame rate mode : Constant Frame rate : 7.868 FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.123 Stream size : 41.8 MiB (100%) Source stream size : 41.8 MiB (100%) Writing library : x264 core 152 r2851 ba24899 Encoding settings : cabac=1 / ref=3 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=7 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=1 / me_range=16 / chroma_me=1 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=6 / lookahead_threads=1 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=3 / b_pyramid=2 / b_adapt=1 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=250 / keyint_min=7 / scenecut=40 / intra_refresh=0 / rc_lookahead=40 / rc=crf / mbtree=1 / crf=23.0 / qcomp=0.60 / qpmin=0 / qpmax=69 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 mdhd_Duration : 694481 Codec configuration box : avcC
are details of the original video
and yes, i agree, maybe issue is due to low frame/second. and so how to enhance video ? -
try this one:
Code:ffmpeg -i in.mp4 -filter:v "setpts=PTS/1.5,fps=25" out.mp4
Slightly Jerky Video-Can It be Smoothed?
By Alwyn in forum RestorationReplies: 17Last Post: 6th Jun 2023, 00:55 -
Jerky interleaved video after encoding M2TS file with VirtualDub
By GD314 in forum Video ConversionReplies: 3Last Post: 10th Jul 2021, 20:31 -
Jerky Video - Fps issue??
By vinckles in forum Video ConversionReplies: 2Last Post: 27th Jul 2019, 11:42 -
VSDC outputting jerky video
By benanna88 in forum EditingReplies: 1Last Post: 24th Jul 2019, 06:38 -
Jerky Video play
By ro2124 in forum Newbie / General discussionsReplies: 2Last Post: 25th May 2019, 05:52
