Hello!
I am trying to record a m3u8 link (via any method), and everything that I try fails to produce audio/video that are synced.
At first, I tried to use the "Open Network Stream" > "Stream" feature in VLC. This records the file just fine, but it stops the recording whenever the segment changes (i.e., the TV channel goes to commercial break or vice-versa). I also tried using the record feature, but with the same result.
Then, I moved on to OBS (I know this is not the most efficient solution, but I just need something that works). I tried to record using a "Media Source" and a "VLC Video Source." Both of these resulted in similar problems.
Finally, I have tried ffmpeg. This seemed to work, as the stream would continue to record over the change in segment (commercial break). But, now there is a new problem. The audio and video become out of sync. They are not consistently out of sync (such as the audio being one second behind the video), but it gets worse and worse as the video goes on.
What I believe to be happening is that the last commercial/segment before they return from commercial break is being skipped in the video recording. The recording always begins in-sync, but grows progressively worse after each commercial break. For now, this has been (tediously) fixed by re-syncing the audio and video in a video editor, but takes a lot of time.
Here is the command I am using with ffmpeg:
(I have changed the actual link to "[link]" to avoid copyright issues)Code:ffmpeg -i [link] -c copy recordingfilename.mkv
(Note: when I just watch (not stream) the link in VLC, there is no issue. I guess VLC has a different way of syncing the segments than other methods.)
What can I change to be able to record this without issue?
Thank you so much for any help! Much appreciated!
	Last edited by thestormarchive; 9th Dec 2023 at 13:49. Reason: Included extra relevant detail.
  Can someone help me get the m3u8 file for this live video link?By infinityhaitian in forum Video Streaming DownloadingReplies: 5Last Post: 18th Dec 2023, 16:37
  No Audio in m3u8 linkBy Frieman44 in forum Video Streaming DownloadingReplies: 2Last Post: 31st Oct 2023, 15:29
  HLS Streaming download encoding results in audio/video sync issueBy CaptureBox in forum Video Streaming DownloadingReplies: 3Last Post: 15th Jan 2023, 01:41
  download m3u8 link can Preview video but no soundBy takheang303 in forum Video Streaming DownloadingReplies: 7Last Post: 21st Aug 2021, 15:31
  Trying to screen record streaming video w/ movavi...audio sync issuesBy Benny in forum Newbie / General discussionsReplies: 1Last Post: 2nd Feb 2020, 17:14
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
