I already told you what I think the problem was. Re-read my comments, and the fix, which you have quoted TWICE. I will not repeat it again.
DVD-flick possibly does not like mkvs whereas DVD Styler and AVStoDVD are more compliant.
Results 31 to 36 of 36
I'm wanting to put an update out now
I was able to make 2 successful previews
1. One that just had a built in template
2. With the custom backgrounds i wanted
I also made a successful disc with everything i wanted i only made 2 mistakes that were my fault i put some episodes out of order and i forgot to add a select button on the menu screen I'll look around to fixing that
I have 2 final questions can i just use the same file and just swap episodes since i want to use the same menu and chapters screen for every disc? And how could i delete each set of files once i burn them to regain space?Last edited by TheCurious?; 10th Dec 2023 at 18:40.
While editing some DVD project in DVD Styler, I successfully deleted videos that had already auto-generated chapters, replacing them with other videos. DVD Styler does a good job removing the chapters and auto-generating new ones when adding different videos.
In addition, when using mkv files, be sure about the video track. The episode you shared earlier has a HVEC (H265) video, which is not supported as much as H264. Nevertheless, I was able to create a DVD from a template using chapters (not titles). Two chapters were auto-generated and the DVD was created, which I could play without problem using MPC-HC.
As the video track in your mkv file has 29fps, I generated a NTSC 16:9 DVD using 2-pass VBR. -
Gee man !
There is nothing 'special' about deleting data after you successfully burn the folders to disc (and confirm that the disks are working) -
You mean deleting the generated DVD, i.e. vob files? Just go to the folder where DVD Styler generated your DVD (which you already burned to disk as you said) and delete it together with the audio_ts and video_ts folders.
Edit: Sorry DB83, I missed your reply. I agree.
Help with DVD Styler audio and subtitle menu please...
By framistat in forum Authoring (VCD/SVCD)Replies: 7Last Post: 27th Dec 2021, 18:06 -
Dvd Styler Menu quality issues
By winman42 in forum Authoring (DVD)Replies: 0Last Post: 26th Dec 2020, 16:57 -
DVD Styler one menu settings help
By Mikeymoo2351 in forum Authoring (DVD)Replies: 0Last Post: 21st Dec 2020, 09:18 -
Menu creation advice needed, possibly with DVD-Styler
By Reddwarf4ever in forum Authoring (Blu-ray)Replies: 15Last Post: 8th Sep 2020, 04:46 -
DVD Styler Menus Not Working in DVD Player
By Mikeymoo2351 in forum Authoring (DVD)Replies: 5Last Post: 25th May 2020, 16:29
