    Dec 2023
    egypt
    hello
    i have problem with download video from mpd protected into ts and m3u8 list,
    the problem is the video is laggy sometimes
    and the sound delayed for 3 ot 5 second and back again and video freezing every 1 min
    this a huge problem to me
    this the command i used
    PHP Code:
    ./ffmpeg -cenc_decryption_key blablabla -copyts -start_at_zero -copytb 0 -fflags +igndts -i https://shls-live-ak.akamaized.net/out/v1/ac12f8988d3945e9974702265620b01e/index.mpd -map 0:8 -map 0:9 - -af "aresample=async=1:first_pts=0" -f segment -segment_format mpegts -segment_time 4 -segment_list_size 6 -segment_list_flags +live+delete -segment_list_type m3u8 -segment_list /home/myuser/public_html/test/60_.m3u8 -fflags +genpts /home/myuser/public_html/test/60_%d.ts
    also i see this problem in terminal
    PHP Code:
    [segment 0x55be3496e080Non-monotonous DTS in output stream 0:1previous5937737current5935738changing to 5937738. This may result in incorrect timestamps in the output file
    some videos for the problem is attached
    sorry for my bad english
  2. share public link video , or if not dm me
    Dec 2023
    egypt
    thanks for reply
    the url and keys sent
    to your inbox
    the problem happend with every mpd protected
    mpd non protected is worked fine without any problem
  4. use N_m3u8DL-RE
    Dec 2023
    egypt
    use N_m3u8DL-RE
    N_m3u8DL-RE create only 1 file and the file become huge size
    i want creat m3u8 list like ffmpeg does , N_m3u8DL-RE not support create m3u8
