hello, everyone! i'm having a little bit of a problem with my chapter timing being off.. i'm following Sefy's guides, and i have copied two movies.. Little Nicky and The Sound of Music. Little Nicky had some problems with the chapters, and it was more noticable at the end of the movie, but Sound Of Music was just off badly.. it was more noticable as the movie progressed. Anyone have suggestions?? I can tell you what progs i'm using for each step..
Smartripper to rip
Chapter X-tractor to rip chapters
DVD2AVI to frameserve
and TMPGEnc to encode..
i check the times that there's supposed to be a new chapter, and it's totally off.. someone please help me!!
With what did you include the chapters ? VCDEasy or TSCV ?
Email me for faster replies!
Best Regards,
Sefy Levy,
Certified Computer Technician. -
i just checked the timing through tmpgenc when i made my mpg files.. the timing didn't come out right.
Now I lost you, with what did you do the Chapters on ? VCDEasy or TSCV ?
and did you make sure you are using Closed GOP's on TMPGEnc ?Email me for faster replies!
Best Regards,
Sefy Levy,
ok, what i did was extract the info with chapter x-tractor.. before i encoded the wav and d2v files through tmpgenc, i checked where i should split the movie for the other discs (sound of music is 2.5+ hours long, so it's 3 discs), and when i checked the timings for the chapters, it didn't match up quite right.. it did at first, but as the movie progressed, the chapters would get more and more off. the scene would change way after the chapter changes.. (i.e. the chapter info says that the 21st chapter is supposed to start at 1:30.45, but the scene isn't totally over until 1:33:45). for instance, i split disc 1 after the song "do-re-mi", but the song isn't finished when the chapter x-tractor info says it is.. it cuts out early.
so, in other words, i haven't gotten to the part of your method where i use vcdeasy or tscv yet.. i'm still at the encoding stage.. and by the way, what does closed gop's do? thanks for helping so far, sefy!! your guides are awesome! -
Ok, I know what happened, what you did, is that on the second and onward CD's, you typed the begining as 0:00:00 instead of the ending time of the first movie, so VCDEasy didn't setup the chapters correctly on the other discs
Best Regards,
Sefy Levy,
no, sefy!! that's not my problem. i know how to do the offset for multiple cds.. we're still talking about the first cd. the chapters are almost right on at the beginning, but progressively off by more at the end. of the first disc.
I apologise, I misunderstood you previously, so as for your problem, your best way would be to manually set the chapters, and as for your previous questions the GOP's are exactly the points where the program actually puts the chapter in.
Best Regards,
Sefy Levy,
MultiAVCHD problems; chapter selection crashes program; changing title
By Yanta in forum Newbie / General discussionsReplies: 0Last Post: 14th Sep 2011, 16:48 -
MKV chapter file extraction problems
By ikarishinji41 in forum EditingReplies: 1Last Post: 22nd Mar 2010, 11:03 -
DVDLab Pro output Chapter problems
By ArtOfLosingMFZB in forum Newbie / General discussionsReplies: 4Last Post: 9th Mar 2009, 20:38 -
Copying the in sync timing of language1 to out of sync timing of language2
By mago1978 in forum SubtitleReplies: 0Last Post: 19th Jan 2009, 15:05 -
Problems with timing using Subtitle Workshop
By Antus77 in forum SubtitleReplies: 1Last Post: 24th Jun 2007, 20:27
