Any time I accidentally hit my wooden desk with my leg or elbow the shockwave travels to the other side of the table to the VCR. From what I have learned VCRs are extremely fragile and any kind of vibration causes drift. Putting a book under the VCR could cause an incline, causing drift. If I put the VCR farther away, say on another table, it's too far from my PC. If I put my DVD recorder under the VCR the heat from the DVD recorder will cause the VCR to overheat. I recorded a tape last night and accidentally hit the table trying to swat a fly. I am tempted to record the same VHS tape again in case it affected the recording. Is it reasonable to do this, or would it be a waste of time? What do you do to avoid this problem?
Scare away the flies before capturing
Seriously: Play and watch the capture around the time when you hit the table, then decide whether it's worth to
- recapture the full tape
- recapture the damaged scene only and replace it in the original capture using an editor
- Depending on the severity of the damage apply a filter to "repair" the damaged section
- etc.
Only YOU can decide what is adequate.
VCR Vibration Table Vibration Problem when Capturing
By Ferrari420 in forum Newbie / General discussionsReplies: 0Last Post: 5th Dec 2023, 10:04 -
Can P.G. Shifter solve this? (VHS capturing)
By the98 in forum Video ConversionReplies: 0Last Post: 21st Aug 2021, 16:45 -
Need help capturing video from VCR
By HuJass in forum Capturing and VCRReplies: 43Last Post: 3rd Apr 2021, 03:22 -
Tripods and vibration dampening - Any proven suggestions?
By pooty13901 in forum Newbie / General discussionsReplies: 16Last Post: 29th Jan 2021, 00:24 -
QTGMC image vibration, motion?
By lordsmurf in forum RestorationReplies: 19Last Post: 10th Sep 2020, 17:18
