I heard QTGMC is the best deinterlacer for videos, but it's very slow. How do I make other deinterlacers like yadif or nnedi have the same quality as QTGMC when I deinterlace videos using them?
Also, which deinterlacer in Shutter Encoder and ffmpeg has the best quality for videos, Yadif, nnedi, or something else? Also, how do I make videos have twice the frame rate when deinterlacing them?
[Attachment 75256 - Click to enlarge]
Results 1 to 11 of 11
bwdif is considered to be pretty good, probably better than yadif
Side note: the speed of QTGMC depends a lot of on the used settings, for most cases Preset="Faster" or Preset="Fast" is enough,..
users currently on my ignore list: deadrats, Stears555, marcorocchini -
detelecine is for reversing 3:2 telecine. That quality is the best if your source has 3:2 telecine (23.976p content in 29.97i interlaced stream)
estdif and w3dif are not very good in general
But it is source dependent; sometimes a specific deinterlacer will not perform well an a particular source, but good on another -
Here is one of information of one of my videos I shall deinterlace.
Code:General Unique ID : 258353246348045939569265620988127380324 (0xC25D067C7E97E681F2DFF58C715C8364) Complete name : title00.mkv Format : Matroska Format version : Version 2 File size : 5.11 GiB Duration : 23 min 53 s Overall bit rate mode : Variable Overall bit rate : 30.6 Mb/s Frame rate : 29.970 FPS Encoded date : 2017-12-12 05:26:37 UTC Writing application : MakeMKV v1.10.8 win(x64-release) Writing library : libmakemkv v1.10.8 (1.3.5/1.4.7) win(x64-release) Video ID : 1 ID in the original source medium : 4113 (0x1011) Format : AVC Format/Info : Advanced Video Codec Format profile : High@L4.1 Format settings : CABAC / 4 Ref Frames Format settings, CABAC : Yes Format settings, Reference frames : 4 frames Format settings, picture structure : Frame Codec ID : V_MPEG4/ISO/AVC Duration : 23 min 52 s Bit rate mode : Variable Bit rate : 28.3 Mb/s Maximum bit rate : 40.0 Mb/s Width : 1 920 pixels Height : 1 080 pixels Display aspect ratio : 16:9 Frame rate mode : Constant Frame rate : 29.970 (30000/1001) FPS Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Interlaced Scan type, store method : Interleaved fields Scan order : Top Field First Bits/(Pixel*Frame) : 0.456 Time code of first frame : 01:00:00:0000000000 Stream size : 4.72 GiB (92%) Language : English Default : No Forced : No Original source medium : Blu-ray Audio ID : 2 ID in the original source medium : 4352 (0x1100) Format : PCM Format settings : Little / Signed Codec ID : A_PCM/INT/LIT Duration : 23 min 53 s Bit rate mode : Constant Bit rate : 2 304 kb/s Channel(s) : 2 channels Sampling rate : 48.0 kHz Frame rate : 30.000 FPS (1600 SPF) Bit depth : 24 bits Stream size : 394 MiB (8%) Title : Stereo Language : Japanese Default : Yes Forced : No Original source medium : Blu-ray Menu 00:00:00.000 : en:Chapter 01 00:03:11.891 : en:Chapter 02 00:06:54.046 : en:Chapter 03 00:09:25.665 : en:Chapter 04 00:12:03.956 : en:Chapter 05 00:15:20.519 : en:Chapter 06 00:17:06.158 : en:Chapter 07 00:18:30.542 : en:Chapter 08 00:19:04.009 : en:Chapter 09 00:21:43.201 : en:Chapter 10 00:23:51.997 : en:Chapter 11
Mediainfo is not necessarily accurate in terms of actual content - there is no way to tell until you look at it - You have to examine the fields to determine what type of content it is
eg. Progressive "24p" content arranged in fields (encoded interlaced) is telecine.
If you double rate deinterlace, and examine a scene with constant motion, and there is movement every frame, then that scene has interlaced content . If there are 3 duplicates, 2 duplicates, then it's "23.976p" . If there are duplicates, then it's "29.97p" . There are other types of patterns but those are the most common
Animation is almost always progressive content, except for some effects, overlays, credits . You would rarely deinterlace anime or most types of animation, cartoons
In general, if you deinterlace progressive content, you degrade it . In general, for progressive content that is telecined - you should field match and decimate (= inverse telecine) , instead of deinterlacing -
If the content is interlaced, then double rate deinterlace it . This should give you 59.94p , with movement every frame . If it doesn't - then you did something wrong, or it's not actually interlaced
QTGMC is probably the "best" overall, but there are some cases where it produces worse results
For the other in your list, bwdif is probably the top choice overall, but sometimes the artifacts are sharper as well - it's a tradeoff
Do some short tests on your source and see what you like better. There is no best at everything -
It's source dependent. QTMGC can produce "worse" results on some sources , and according to some opinions
It's not all cut and dry either - there are apsects where QTGMC slightly better, aspects where it's slightly worse. It depends on what aspect(s) you consider more important. Don't take anyone's word for it, do some tests yourself and look. Some people hate the detail loss, some people hate that other deinterlacers flicker, some people just hate...
ie. There are pros/cons . QTGMC is still probably the best overall for most sources, at least in terms of temporal consistency and smoothness, fewer aliasing and flicker artifacts. However , the biggest negative of QTGMC is the net effect of denoising and blurring to order achieve that temporal smoothness . You can adjust the many settings to your tastes and for the source to reduce the problems, but there is often texture and detail loss ; that's probably the most common complaint .
Sometimes you can get temporal artifacts, ghosting. The temporal smoothing can sometimes be counterproductive for certain workflows (eg. deblending a field blended source). An non temporal deinterlacer would never get temporal artifacts, but they tend to have more flicker and temporal inconstencies - again a trade off
Default QTGMC settings often make image look like waterpainting (overdenoised and oversharpened). You definitely should adjust settings for each source to get ideal results, and to be fair the oversharpening is mentioned in the instructions. I almost always decrease sharpness right away, unless source is blurry
Sometimes the motion estimation is wrong and you get wobbling areas in parts of frames - it's a related problem with mvtools2 (can also affect mvtools2 based denoisers). This often affects animation scenes where there is low or no motion, hold frames - you get warping artifacts
And what about nnedi? How do you deinterlace videos using it in ffmpeg?
The settings for ffmpeg nnedi are in the documentation
https://ffmpeg.org/ffmpeg-filters.html#nnedi
There are published comparisons between deinterlacers, but you should really test them on your source(s) and play with the settings. A lot of it can be personal taste as well.
QTGMC Deinterlacing Presets
By Jay123210599 in forum Newbie / General discussionsReplies: 3Last Post: 4th Nov 2023, 22:26 -
QTGMC MKV Deinterlacing
By Jay123210599 in forum Newbie / General discussionsReplies: 6Last Post: 26th Oct 2023, 16:16 -
Flickering after deinterlacing with QTGMC
By Sunk in forum Capturing and VCRReplies: 5Last Post: 24th Aug 2023, 11:48 -
QTGMC motion artifacts/Deinterlacing help
By killerteengohan in forum RestorationReplies: 5Last Post: 2nd Apr 2020, 21:20 -
QTGMC deinterlacing
By Katherine1 in forum RestorationReplies: 2Last Post: 10th Feb 2019, 10:02
