  1. Banned
    Oct 2023
    Los Angeles
    How do you batch process multiple videos at once using FlowFrames? Which of its AI models would be best to use for anime, TV shows, cartoons, live-action stuff, and movies?
    Also, does FlowFrames give better results than Shutter Encoder, Avisynth RIFE, SVP, MVTools2 and SVPFlow with AVISynth?
  2. Did you even read couple of lines from google before posting this. It looks it is basically RIFE gui + some others methods, where rife perhaps gives better results.
  3. Banned
    Oct 2023
    Los Angeles
    Wait, it uses AVISynth RIFE? Does this mean it gives the same results?
  4. If same model is selected with same RIFE arguments then yes.
    Not sure how cuda, cuDNN or tensoRT versions (tools needed for this) have a role in this for a final outcome.
