Results 1 to 13 of 13
  1. Since more folks are using models from https://openmodeldb.info/ what do you use for temporal stability to not end up with a result like the file I attached?
    QTGMC with InputType=3 seems to help somewhat, but I was wondering what others came up with.
    Cu Selur
    Aug 2017
    Do not use lossless encodes. I find that an encode at CRF 13 or 14 provides much more stable results than feeding in a lossless video with a bunch of random noise preserved. That noise gets converted to “detail” which causes a lot of temporal instability.
  3. Hmmm,.. so basically smoothing out details from the source.
    Aug 2017
    Essentially yes. At CRF 13 a video is going to be pretty much "lossless" to human eyes, but it makes a noticeable difference to AI upscaling since it's much more temporally consistent. And as we know, these AI upscalers do not have any temporal coherence, so I think you need to add it in somewhere.
  5. My idea: Don't use A. I. upscalers.
  6. My idea: Don't use A. I. upscalers
    Don't know of any non ml/ai based upscaler that comes anywhere near those results when upscaling the attached source to 1280x1024.
    (especially when codeformer is added)
    So if you know an alternative, please share.
    Cu Selur
  7. Definitely not. I didn't know, it was that bad.
    In really most cases I'd always prefer non-A.I.-resizing plus unsharp masking(s) - but here I pass.
    It seems you'll need some A.I.-based temporal smoother...
  8. Problem is that both '4x_Faces_N_250000.pth' and 'CodeFormer' only work frame-by-frame with no temporal concepts, so this is an extreme case.
    (Hoping that there will be a follow up paper&co in the next few years that addresses video.)
    Cu Selur
    Ps.: Attached a QTGMC input type 3 version of the Face+CodeFormer file.
  9. QTGMC input type 3 sometimes works well, sometimes there remains a lot of combing, didn't find out yet for what reason exactly. Deinterlacing here looks fine, but much too much temporal smoothing (how does it look with stabilizenoise=false, tr2=0 ?) Sorry, no time to test myself, early tomorrow big voyage.
  10. There was no deinterlacing, on my way to bed myself, but if I find some time I'll look at it tomorrow.
  11. Ok, residual de-combing and artefacts-removing.
  12. Adding "stabilizenoise=false, tr2=0" doesn't really make a difference. (see attachement)
    Cu Selur
  13. btw. can someone who used Topaz and has some experience with it show what Topaz will do when upscaling suzie_lossless..mp4 ?
