Results 1 to 20 of 20
    Apr 2007
    In 2009 I made 20 AVI videos for a video screen saver. I found them looking through an old hard drive and when I played them in Potplayer, some of them wouldn't play the audio all the way through. I made these for a PC for a convention* which was setup just for playing Portal, with the AVI screen saver as an attract mode.
    I tried them in Windows Media Player, all fine. Same for MPC-HC and VLC. Movies and tV in Win10 can't play the video but does play the audio completely. FormatPlayer plays it all but with snaps and crackles in the audio.
    AVIdemux glitches out on the audio with an early stop just like Potplayer.
    Here's a folder link with the AVI files and the AVI screen saver to use them with. https://file.io/RVkNM4bgIMsZ
    *Of course whomever was in charge of PC gaming that year had a problem with it and screwed it up instead of finding *me* who had put together all the retro PCs that year for the Starcraft LAN and other PC games. "I just turned it on and it was like that!" Yeah, sure it was. I had restarted it three times after I got it all set up, to be sure Windows wasn't going to do anything hinky. It didn't just change the wallpaper, delete desktop shortcuts and move others around, and bollix up some other things all by itself to where Portal wouldn't run.
    May 2005
    Australia-PAL Land
    file.io says the file has been deleted.
    Apr 2007
    Here it is in a RAR file https://file.io/665VG2wIev5X
    May 2005
    Australia-PAL Land
    Still getting the Deleted message:
    "The transfer you requested has been deleted.".
    Apr 2007
    Maybe thins one will allow it. Auto delete in 6 days https://filebin.net/vbogx3r2i9g783e5
    Apr 2007
    This one will keep it if it's downloaded often enough, or 7 days https://uploadnow.io/f/NbTsT8y
    Apr 2007
    I set this one to expire in 90 days https://oshi.at/VfgQ
    May 2005
    Australia-PAL Land
    Both of those are causing Malwarebytes to have a fit. I'd suggest Google Drive.
    Apr 2007
    https://drive.google.com/file/d/12mntOvJJSqAE9M-ObXYa16WJVCgGeeKz/view?usp=sharing
    Edit: File replaced with archive containing the fixed videos.
    May 2005
    Australia-PAL Land
    That Google Drive file/folder works. That audio isn't good, is it. I have no suggestions on how to fix it.
    Mar 2008
    Many of the files have a section where it is just a buzzing sound, and the rest is OK.
    For example, this highlighted section in Audacity
    Apr 2007
    The buzzing is deliberate, it's a sound effect from the Portal game. The problem is with some of the video files in some playing software, the audio stops playing before the end of the video. 00, 03, 08, 13 are the ones with the problem.
  13. I tried them in Windows Media Player, all fine. Same for MPC-HC and VLC. Movies and tV in Win10 can't play the video but does play the audio completely. FormatPlayer plays it all but with snaps and crackles in the audio.
    "Movies and tV in Win10" would require a cinepak directshow decoder to playback those files.
    "FormatPlayer" (never heard of it) probably has issues with mono audio.
    Convert the video to something other than cinepak if you want more players to support it.
    Convert the audio to stereo if you want more players to support it.
    May 2005
    Australia-PAL Land
    What video format do you want them in? I am able to open 03 in Virtual Dub and I encoded it in H264 and AAC Stereo.
    Apr 2007
    I want the ones with the audio issue to not have the issue so they'll work with the AVI Screen Saver without the audio stopping early.
    May 2005
    Australia-PAL Land
    Try this one. All I did was make it Stereo.
    Apr 2007
    Same issue in Potplayer. Cuts off in the middle of proceed. AVIdemux on the glitchy files cuts off sooner, only plays the starting buzz.
    I don't remember what software I used to put the audio together. I just put the buzz in followed by another sound from the game and apparently it didn't seamlessly join on the four files, left something which *some* players see as an end of file while others will just ignore it and play through.
    IIRC the software I used to make the AVIs played them all fine and whatever other playing software did too.
    The AVI Screen Saver does work in Windows 10 and it plays the four AVIs without a problem on my system. I don't remember if it had this issue on XP, which is what I put on the PC I put together to play only Portal.
    Anyway, they have a bug and it bugs me that they do.
  18. Member
    May 2005
    Australia-PAL Land
    Done. I recoded them "back" into Cinepak and MS ADPCM in Virtual Dub2. The video was causing the issue with AVIDemux, and interestingly, those 4 files wouldn't display thumbnails in Windows Explorer, whereas all the others do.
    Apr 2007
    Thank you very much!
    May 2005
    Australia-PAL Land
    My pleasure. I had a chuckle at some of the "instructions" in the clips!
