Can't find PSSH on video decryption site
site - https://tv.volia.com/VOD_ASSET/details/21552143?parentId=10016
Licence URL - https://drm.ott.volia.com:8063/?deviceId=YmEzMzEzZGEtMmMxNS0zYTU1LThmY2MtZWI0MWQzOWZkZDc3
MPD file - https://l25.ott.volia.com/vod/ch143/The_Upside_2019_Lnorm_UA/_/Vod_DASH_WV/The_Upside_...9_Lnorm_UA.mpd
uuid:edef8ba9-79d6-4ace-a3c8-27dcd51d21ed
default_KID="68d1edf0-b9f4-7bf0-fc7f-4d7307f00313"
Function - MediaKeySession::generateRequest found PSSH --AAAAW3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADsIARIQaN Ht8Ln0e/D8f01zB/ADExoRdmVyaW1hdHJpeGt5aXZza2kiC3I9NTAwJnM9ODc4KgVT RF9IRAAAA1pwc3NoAAAAAJoE8HmYQEKGq5LmW+CIX5UAAAM6Og MAAAEAAQAwAzwAVwBSAE0ASABFAEEARABFAFIAIAB4AG0AbABu AHMAPQAiAGgAdAB0AHAAOgAvAC8AcwBjAGgAZQBtAGEAcwAuAG 0AaQBjAHIAbwBzAG8AZgB0AC4AYwBvAG0ALwBEAFIATQAvADIA MAAwADcALwAwADMALwBQAGwAYQB5AFIAZQBhAGQAeQBIAGUAYQ BkAGUAcgAiACAAdgBlAHIAcwBpAG8AbgA9ACIANAAuADAALgAw AC4AMAAiAD4APABEAEEAVABBAD4APABQAFIATwBUAEUAQwBUAE kATgBGAE8APgA8AEsARQBZAEwARQBOAD4AMQA2ADwALwBLAEUA WQBMAEUATgA+ADwAQQBMAEcASQBEAD4AQQBFAFMAQwBUAFIAPA AvAEEATABHAEkARAA+ADwALwBQAFIATwBUAEUAQwBUAEkATgBG AE8APgA8AEsASQBEAD4AOABPADMAUgBhAFAAUwA1ADgASAB2AD gAZgAwADEAegBCAC8AQQBEAEUAdwA9AD0APAAvAEsASQBEAD4A PABDAEgARQBDAEsAUwBVAE0APgB3AEsATwBiAGwAZQBJAEYATw BjADQAPQA8AC8AQwBIAEUAQwBLAFMAVQBNAD4APABMAEEAXwBV AFIATAA+AGgAdAB0AHAAcwA6AC8ALwBkAHIAbQAuAG8AdAB0AC 4AdgBvAGwAaQBhAC4AYwBvAG0AOgA4ADAANgAyAC8AUABsAGEA eQBSAGUAYQBkAHkALwByAGkAZwBoAHQAcwBtAGEAbgBhAGcAZQ ByAC4AYQBzAG0AeAA8AC8ATABBAF8AVQBSAEwAPgA8AEwAVQBJ AF8AVQBSAEwAPgBoAHQAdABwAHMAOgAvAC8AZAByAG0ALgBvAH QAdAAuAHYAbwBsAGkAYQAuAGMAbwBtADoAOAAwADYAMgAvAFAA bABhAHkAUgBlAGEAZAB5AC8AcgBpAGcAaAB0AHMAbQBhAG4AYQ BnAGUAcgAuAGEAcwBtAHgAPAAvAEwAVQBJAF8AVQBSAEwAPgA8 AC8ARABBAFQAQQA+ADwALwBXAFIATQBIAEUAQQBEAEUAUgA+AA == --but it is too long and not suitable for video decoding
help me find real pssh?
Results 1 to 21 of 21
AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEGjR7fC59Hvw/H9NcwfwAxM=
Hello. Help find the correct keys to decrypt the video
AAAAMnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAABISEGjR7f C59Hvw/H9NcwfwAxM= -->not suitable for generating valid keys, I don't know why
Help! -
that deviceId in license url maybe expire fast or one time used. i got time out error, also that mpd link cant access(404), so from which country?
This PSSH should be correct (getting it from the 1080p init.mp4 file:
And can be sure since mp4dump displays same KID that you have for the init file.Code:>pssh_from_init.py Extracting PSSHs from init file: init.mp4 Searching pssh offsets AAAAW3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADsIARIQaNHt8Ln0e/D8f01zB/ADExoRdmVyaW1hdHJpeGt5aXZza2kiC3I9NTAwJnM9ODc4KgVTRF9IRA==
Can't test it since need headers from licence.Code:default_KID = [68 d1 ed f0 b9 f4 7b f0 fc 7f 4d 73 07 f0 03 13]
[ftyp] size=8+16
major_brand = iso6
minor_version = 0
compatible_brand = iso6
compatible_brand = dash
[moov] size=8+1617
[mvhd] size=12+96
timescale = 48000
duration = 0
duration(ms) = 0
[pssh] size=12+79
system_id = [ed ef 8b a9 79 d6 4a ce a3 c8 27 dc d5 1d 21 ed]
data_size = 59
[pssh] size=12+846
system_id = [9a 04 f0 79 98 40 42 86 ab 92 e6 5b e0 88 5f 95]
data_size = 826
[trak] size=8+512
[tkhd] size=12+80, flags=7
enabled = 1
id = 1
duration = 0
width = 0.000000
height = 0.000000
[mdia] size=8+412
[mdhd] size=12+20
timescale = 48000
duration = 0
duration(ms) = 0
language = ukr
[hdlr] size=12+41
handler_type = soun
handler_name = Bento4 Sound Handler
[minf] size=8+319
[smhd] size=12+4
balance = 0
[dinf] size=8+28
[dref] size=12+16
[url ] size=12+0, flags=1
location = [local to file]
[stbl] size=8+259
[stsd] size=12+179
entry_count = 1
[enca] size=8+167
data_reference_index = 1
channel_count = 2
sample_size = 16
sample_rate = 48000
[btrt] size=8+12
[esds] size=12+27
[ESDescriptor] size=2+25
es_id = 0
stream_priority = 0
[DecoderConfig] size=2+17
stream_type = 5
object_type = 64
up_stream = 0
buffer_size = 0
max_bitrate = 128000
avg_bitrate = 0
DecoderSpecificInfo = 11 90
[Descriptor:06] size=2+1
[sinf] size=8+72
[frma] size=8+4
original_format = mp4a
[schm] size=12+8
scheme_type = cenc
scheme_version = 65536
[schi] size=8+32
[tenc] size=12+20
default_isProtected = 1
default_Per_Sample_IV_Size = 8
[stts] size=12+4
entry_count = 0
[stsc] size=12+4
entry_count = 0
[stsz] size=12+8
sample_size = 0
sample_count = 0
[stco] size=12+4
entry_count = 0
[mvex] size=8+32
[trex] size=12+20
track id = 1
default sample description index = 1
default sample duration = 0
default sample size = 0
default sample flags = 0 -
What data do you need?
ERROR
HTTPSConnectionPool(host='drm.ott.volia.com', port=8063): Max retries exceeded with url: /?deviceId=YmEzMzEzZGEtMmMxNS0zYTU1LThmY2MtZWI0MWQz OWZkZDc3 (Caused by ConnectTimeoutError(<urllib3.connection.HTTPSConne ction object at 0x7f4906297190>, 'Connection to drm.ott.volia.com timed out. (connect timeout=10)'))Last edited by nadya86; 25th Feb 2024 at 12:20.
Done.
PSSH
License URLCode:AAAAW3Bzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADsIARIQaNHt8Ln0e/D8f01zB/ADExoRdmVyaW1hdHJpeGt5aXZza2kiC3I9NTAwJnM9ODc4KgVTRF9IRA==
Just user-agent in headers and:Code:https://drm.ott.volia.com:8063/?deviceId=YmEzMzEzZGEtMmMxNS0zYTU1LThmY2MtZWI0MWQzOWZkZDc3
Code:--key 68d1edf0b9f47bf0fc7f4d7307f00313:0f58e1c1d33eaa564b13c24408a578a4
I thank you for your help. Tell me.
I did not understand where you found key ? Foto?
Find pssh
By hansoljun in forum Video Streaming DownloadingReplies: 1Last Post: 12th Sep 2023, 03:54 -
How to find PSSH and m3u8 for Youku site?
By andertjf in forum Video Streaming DownloadingReplies: 12Last Post: 18th Jul 2023, 03:36 -
Different PSSH in mpd, EME logger and PSSH Box Generator
By Kevste in forum Video Streaming DownloadingReplies: 4Last Post: 31st May 2023, 23:24 -
Help me find PSSH for vrt.nu
By lovelybloodflow in forum Video Streaming DownloadingReplies: 6Last Post: 19th Jun 2022, 11:04 -
Does anyone know how to find the license and pssh on iq.com?
By artemisluck in forum Video Streaming DownloadingReplies: 1Last Post: 29th May 2022, 15:00
