I'm running a 400mhz PII with 256mb ram. I'm trying to convert an 89 minute movie in Tmpgenc. I've used kingviper's template and the generic ones. But the time of conversion is over 13 hours for sVCD. Is this right? If anyone has any helpful tips to lowering conversion time.
Also i'm trying to make an 89 minute movie into a 2 part SVCD, but when i split the movie into two the disk capacity is well over 130%. I'm sure there is a way to make this smaller, any help would be great thanks.
CPU encoding time is mainly dependent on 2 things:Originally Posted by changohead
1. CPU muscle (more is faster, less is slower - very low speed CPUs take a really long time to encode)
2. Quality settings (higher quality takes longer)
Your encode is taking roughly 13 hours to encode ~1.5 hours of video to SVCD. That's about 8x, and that might be about normal for a 400MHz CPU. If you are changing resolution from the source file (i.e. 320x240 to 480x480) that also takes exra time. If the source file is compressed (such as DivX) remember your CPU has to decompress and recompress each and every frame (or should I say decode and re-encode)..As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war." -
all the time spent on conversion and rendering my computer unusable makes it almost not worth it. One movie I converted took about 20 hours to dvd rip, extract audio in dvd2avi, and convert in tmpgenc. and the end result was less than desirable. Instead of building myself a new supercomputer why not just buy a new dvd-rw for $350.
still have to convert with a dvd-r/w. That computer you have is going to take a LONG time to do anything with video. I bought a K7S5a, Athlon 1.7, and 256 pc2100 for under $200.00
what kind of converting is there with a dvd-rw? Doesn't it just copy dvds? Where did u find such a fast computer for so little?
Get used to long conversion times. I'm running an AMD 1700 XP with 256 MB RAM, and to convert a captured AVI full-length movie into M2P format for DVD authoring routinely takes more than 12 hours on my machine. I usually capture the video in the evening, then let my PC run overnight for file conversion. The next evening I spend authoring the DVD.
- Spagyrist :P
Decrease Conversion Time
By CranialBlaze in forum Video ConversionReplies: 0Last Post: 10th Nov 2010, 04:23 -
Video Run Time Gets Cut in half - and other conversion problems...
By scotsgael in forum ffmpegX general discussionReplies: 0Last Post: 3rd May 2010, 01:41 -
Framerate conversion (again sorry) 60p to 25p this time
By Panash in forum Video ConversionReplies: 5Last Post: 2nd Jan 2010, 17:32 -
Removing a running time from vhs conversion
By eiffelgirl in forum EditingReplies: 10Last Post: 4th Dec 2008, 00:41 -
Problem Using Vider Studio 10 - Start Time After End Time
By jmsrickland in forum Newbie / General discussionsReplies: 0Last Post: 31st Jul 2008, 17:48
