I have a DVD source that runs at 25fps. For the reconstruction version, I'm wondering what to enter for tdecimate to remove the ghosting and any dupe frames. Should I use tdecimate, or something else?
For the montage version, it's 25fps progressive, but if I use assumefps to restore it to silent film speed, which fps should I use, and how would I convert the audio in Audacity to fit the slowed-down version?
Thanks!
Source samples: https://mega.nz/folder/cFNCQD7K#hZvrS9uGFuPJDSvCSI9J5A
I couldn't see a good solution for that blurry mess. I tried looking at it frame by frame for a pattern
where you could use selectevery() to choose the frames, but it loses its cadence after the scene changes
For the other one slow it down to 18 fps (original frame rate 25)
25/18 = 1.3888
In Audacity effect/pitch and tempo/change tempo
In the beats per minute box from=13.888, to=10.0
Decimation Question
By ZacharyGeorgeNN in forum DVD RippingReplies: 4Last Post: 13th Dec 2022, 21:35 -
Difficult Decimation Source
By ZacharyGeorgeNN in forum DVD RippingReplies: 5Last Post: 8th May 2021, 16:46 -
Project Propeties
By biferi in forum Newbie / General discussionsReplies: 7Last Post: 20th Jul 2020, 21:47 -
Video still has duplicates after decimation?
By embis2003 in forum RestorationReplies: 3Last Post: 28th Apr 2020, 17:01 -
How to add a project to new project
By Jbreezy in forum Newbie / General discussionsReplies: 3Last Post: 7th Apr 2020, 14:37
