Results 1 to 15 of 15
    Nov 2023
    israel
    Hello everyone,
    I'm trying to use EME Logger to find the PSSH (Protected Media Key System-specific Header) while working with DRM-protected content.
    I've been tracking the MediaKeySession::generateRequest event, but I'm not getting any results at all.
    To illustrate the issue better, I've recorded a video demonstrating the problem.
    I would greatly appreciate any guidance or suggestions on how to correctly use EME Logger to find the PSSH.
    Thank you!
    https://files.videohelp.com/u/308271/bandicam%202023-11-27%2016-46-30-574.mp4
  2. filter init or cenc in console table.
    Nov 2023
    israel
    I couldn't understand what you mean, I would appreciate it if you could attach a screenshot
    Thank you
  4. the two pic just same.
    Nov 2023
    israel
    Thank you very much, much appreciate it!
    Unfortunately it doesn't work on the Udemy :/
    [Attachment 75094 - Click to enlarge]
  6. reload/refresh page and play video
  7. mate use eme logger modded rename it to your local file
  8. lol js file is threaded as virus... its a false positive
    Nov 2023
    israel
    To be honest, it's a bit hard for me to understand.
    A picture is worth 1000 words, I would appreciate it if you could explain with pictures
    Thank you. ♥
  10. On the Console tab filter for "Init Data:" without the quotes. Also make sure that in the Tampermonkey plugin EME Logger is enabled green.
    Dec 2022
    Lesotho
    What is the mod if I may ask?
    Nov 2023
    israel
    I couldn't figure out how to use the file.
    I would appreciate an explanation, thank you very much
  13. Originally Posted by Funx View Post
    Care to explain how you run this version of eme logger? I have several versions that run just fine with Tampermonkey, but this one fails.
    Tampermonkey says that it is full of errors. Numerous undefines.
    Nov 2023
    israel
    someone, something?
