Hi
I'm new here
I have some videos that I recorded from my iPhone 15
Pro that they have HLG-Dolby Vision and saved them in MOV files
I would like to know how can I convert those videos into Blu Ray keeping the HLG-Dolby Vision Metadata, so my player can recognize those metadata
I've tried using tsmuxer, however got an issue about error in Dolby vision to save in blu Ray folder
Any help please?![]()
Yuhan Blu-ray DVD Creator latest version can do it, I have made several discs, but there are two conditions that need to be met:
1. Your video must be shot in landscape mode.
2. The frame rate of your video must be exactly the same as the frame rate set by Yuhan Blu-ray DVD Creator, because Blu-ray supports 23.976fps, 24fps, 25fps, 29.976fps, 50fps, 59.94fps, and the current frame rate of the iphone exactly matches only 24fps, you can also use other software to convert the frame rate, but keep the dolby vision.
for windows:
https://yuhanmedia.com/wp-content/download/bdc_setup.exe
for mac:
https://yuhanmedia.com/wp-content/download/bdc_setup.dmgLast edited by moon_light; 11th Jan 2024 at 03:48.
Yes, landscape mode means horizontal.
You can record 24fps 4k dolby vision video, which is the best choice for producing UHD Blu-ray disc. -
make video everyday
4K UHD Blu Ray Remux to Blu Ray (regular) for burning
By Damirko1981 in forum Authoring (Blu-ray)Replies: 9Last Post: 9th Apr 2025, 20:04 -
BDInfo, VLC, and Video Streams on 4K UHD Blu-ray Discs
By Chris Kelly in forum Software PlayingReplies: 4Last Post: 9th Mar 2022, 05:01 -
UHD to Blu-ray Bitrate?
By kpic in forum Authoring (Blu-ray)Replies: 9Last Post: 5th May 2021, 11:59 -
UHD Blu Ray Spec
By premiumcapture in forum Authoring (Blu-ray)Replies: 3Last Post: 13th May 2020, 22:04 -
Ripbot264 Convert UHD Blu-ray 4k to Blu-ray 1080p
By microhunt in forum DVD RippingReplies: 0Last Post: 23rd Dec 2018, 12:12
