  1. Right now I am encoding Dumb and Dumber from .Avi to .MPG using TMPGEnc. It is only up to 3% and it's been running for 3 minutes already. The movie is about 80 minutes long. Is it supposed to take that long or am I doing something wrong?
  2. the faster your processor, the faster the encoding.
    mine is 800mhz and it usually takes me 2-3 hrs to encode a hour worth of mpg
  3. Originally Posted by DVDKing7
    What CPU are you running? Encoding speed is almost totally dependent on CPU muscle, and also your encoder quality options (faster CPU lessens encoding time, higher quality takes longer).
    As Churchill famously predicted when Chamberlain returned from Munich proclaiming peace in his time: "You were given the choice between war and dishonor. You chose dishonor, and you will have war."
  4. His CPU can't be that slow i'm running 400 mhz and I get 1% in 3-4 minutes. Wish I had money to upgrade
    We were all NEWBIES once and the only stupid question is the one that's not asked?
  5. I am running 800 mhz.
  6. Are you using standard vcd with cbr setting nothing else added
    or svcd?
    Oh yeah your also on the web don't forget!
  7. Ummmmm, by my calculations 3% of 80 is 2.4 - 3 min. to encode 2.4 min is almost realtime!
