I have a H.264 MKV video that I want to deinterlace while changing nothing else. How do I do that using Shutter Encoder and ffmpeg? Also, what is the best deinterlacer to use from both programs and how do I used them convert the frame rate of videos?
Why do you want to do any of this work? Deinterlacing will not make the video better (it actually degrades it slightly). Most TV sets will deinterlace for you.
AVISynth using the QTGMC AVSI script is usually said to be about the best deinterlacer you can get. There is, of course, no such thing as "best" in all circumstances.
As for frame rate conversion, why the heck do you want to do that? Once again, it won't make the video look any better, although it is true that you can make 24 fps film look like 60 fps progressive video, if you don't mind the artifacts that you will inevitably create when doing that work. If you don't want to spend any money, you can use MVTools2, SVPFlow, or several other AVISynth plugins to do frame rate conversion.
If you do frame rate conversion, you will have spent a lot of time, but I don't think the video will look any better.
However, as the French say, "À chacun son goût." -
Thank you for sharing your insights on deinterlacing and frame rate conversion. It's essential to consider the implications of such processes and whether they truly enhance the video quality.
For those navigating financial challenges, exploring options like debt consolidation loans can offer a path towards managing debts more effectively. Consolidating debts into a single loan can simplify payments and potentially save money on interest rates.
If you're interested in learning more about debt consolidation loans and finding the best options available, you can check out this https://fitmymoney.com/best-debt-consolidation-loans/ resource.
Ultimately, it's about making informed decisions that align with your goals and priorities, whether it's regarding video processing or financial management. Thank you for contributing to the discussion!Last edited by vincentevans; 30th Jan 2024 at 09:08.
Theoretically you are right, but practically QTGMC will perform better deinterlace than TV.
Theoretically you are right, but practically RIFE (or Topaz) will perform quite good conversion, e.g. from 30 to 60fps and the video will be significantly smoother. Better than many "enhancers" built into some TVs.If you do frame rate conversion, you will have spent a lot of time, but I don't think the video will look any better.
Mp4Box - Output is generated without frame Width, frame height & frame rate
By Saptarshi in forum Newbie / General discussionsReplies: 0Last Post: 25th Nov 2022, 08:27 -
Bob deinterlacing in AviSynth without doubling the frame-rate?
By orion44 in forum Video ConversionReplies: 11Last Post: 6th Dec 2021, 00:44 -
Best Monitor Refresh Rate, OBS Frame Rate for streamed film movies?
By pmikep in forum Video Streaming DownloadingReplies: 10Last Post: 18th May 2021, 11:13 -
Video capture frame rate vs. final output file frame rate
By Theodore in forum Capturing and VCRReplies: 5Last Post: 18th Apr 2021, 17:48 -
Variabel frame rate / constant frame rate problem with free version of VSDC
By danielschut in forum Newbie / General discussionsReplies: 6Last Post: 11th Jun 2020, 02:50
