Hey folks,
This is a fantastic forum, I appreciate how much work people put in to help others.
I've successfully got my own CDM, all relevant scripts functioning, and can successfully get the keys for a variety of sites. There are however, some sites which seem to have a 2-step process before keys are returned, where a licence request bearing '0x04, 0x08' is sent to the LIC, which then returns a certificate. I modified l3.py in WKS-Keys, and I think that I have functionally been able to repeat the process, alas, doing this then causes me to get an 'RSA key not supported error' in return.
Here is my modified l3.py script:
The information I inferred was that if I sent the '0x04,0x08' as a byte array, encoded the response body in base64 and passed it on to WVDecrypt, that this would then function as normal.HTML Code:import base64, requests, sys, xmltodict import headers from pywidevine.L3.cdm import cdm, deviceconfig from base64 import b64encode from pywidevine.L3.getPSSH import get_pssh from pywidevine.L3.decrypt.wvdecryptcustom import WvDecrypt pssh = input('PSSH: ') lic_url = input('License URL: ') # Define the byte array byte_array = bytearray([0x08, 0x04]) # Send the byte array as a payload (replace 'cert_url' with the actual URL) cert_response = requests.post(lic_url, data=byte_array, headers=headers.headers) cert_response.raise_for_status() # Ensure the request was successful # Base64 encode the response cert_data_b64 = base64.b64encode(cert_response.content) print(cert_data_b64) def WV_Function(pssh, lic_url, cert_data_b64): wvdecrypt = WvDecrypt(init_data_b64=pssh, cert_data_b64=cert_data_b64, device=deviceconfig.device_android_generic) widevine_license = requests.post(url=lic_url, data=wvdecrypt.get_challenge(), headers=headers.headers) license_b64 = base64.b64encode(widevine_license.content).decode('utf-8') wvdecrypt.update_license(license_b64) Correct, keyswvdecrypt = wvdecrypt.start_process() if Correct: return Correct, keyswvdecrypt # Usage correct, keys = WV_Function(pssh, lic_url, cert_data_b64) print() for key in keys: print('--key ' + key)
Alas I get the RSA key issue.
Is there any tips anyone could help me with please? Anything I'm clearly doing wrong? Any guidance would be really appreciated.
Thank-you in advance!
Results 1 to 1 of 1
how to deal with this kind of encrypted m3u8, looks more complex
By shellcmd in forum Video Streaming DownloadingReplies: 3Last Post: 30th Oct 2023, 03:57 -
Complex DL
By mitrixhimself in forum Video Streaming DownloadingReplies: 12Last Post: 4th Nov 2021, 08:14 -
Complex FFMPEG command
By nifaf in forum Video ConversionReplies: 0Last Post: 23rd Sep 2021, 08:28 -
Question on order of video inputs when using ffmpeg and complex filters
By AspiringVideoProcessor in forum Video ConversionReplies: 1Last Post: 16th May 2021, 10:50 -
Video contains many complex overlapping moving parts,need to edit it
By eureka in forum Newbie / General discussionsReplies: 6Last Post: 27th Feb 2021, 00:25
