okay well its old but i was using it in my component system for playing cd,s which worked really well, the dog chewed up the remote control. so on the player itself it has stop, play pause and open. so when i want to forward to a song i cant there is no option. i am guessing that the answer is to find an old dvd/cd player but thought i would ask if there were any ideas anyway
many thanks
I have tried 6 different universal remotes from the Play store on my Samsung phone, none of them work. i got one for the TV and that works fine but none of them for the Akai DVD Player, probably cause it is old i guess.
Still if someone knows of an App that might work please let me know. I would buy a universal remote but i would not be sure that it would work -
Get a physical universal remote as some devices require different types of IR. The Phillips RC122, which is very common and cheap lists Akai DVD players as compatible: https://d15yx0mnc9teae.cloudfront.net/sites/default/files/sup_remote-manual_philips-rc122-twc.pdf
It's a learning remote, so if the codes don't work you may be able to get to to work. They're only $9 at Amazon, but even that's probably more than your player is worth.
Edit: Some of the higher end Logitech Harmony remotes have multiple LEDs to cover more devices. -
Hi thanks for that, come to mention it the apps i got from the phone, one did come up with a IR Error, but i will look at that remote you gave me the link for, but as you say i can probably get one from the pawn shops for around 10 dollars so i will shop around for one.
thanks for the help much appreciated
hp DVD A DH16A burned dvd won't play properly in Panasonic my player
By xorx in forum DVD RippingReplies: 1Last Post: 13th Sep 2023, 12:12 -
Upgrading from Upscaling DVD player to 4k Blu Ray Player
By doffcocker in forum DVD & Blu-ray PlayersReplies: 3Last Post: 11th Apr 2022, 11:47 -
Anyone Know What Player Is Used In This Rare DVD Player?
By hot_spot in forum DVD & Blu-ray PlayersReplies: 9Last Post: 9th Aug 2021, 14:31 -
Sincotec 8150 dvd player and Alba 70S dvd player Reverse Slow Motion?
By vinckles in forum DVD & Blu-ray PlayersReplies: 0Last Post: 16th Sep 2020, 06:52 -
DVD Styler Menus Not Working in DVD Player
By Mikeymoo2351 in forum Authoring (DVD)Replies: 5Last Post: 25th May 2020, 16:29
