I created a video stream using:
(attached bff.m2v and 2023-11-24@15_37_21_4710_01.265)Code:ffmpeg -y -loglevel fatal -noautorotate -nostdin -threads 8 -i "G:\TestClips&Co\files\interlaceAndTelecineSamples\interlaced\bff.m2v" -map 0:0 -an -sn -vf zscale=rangein=tv:range=tv -pix_fmt yuv420p10le -strict -1 -vsync 0 -top 0 -f yuv4mpegpipe - | x265 --input - --fps 30000/1001 --output-depth 10 --y4m --profile main10 --crf 18.00 --interlace bff --range limited --colormatrix bt470bg --sar 8:9 --output "J:\tmp\2023-11-24@15_37_21_4710_01.265"
not I want to multiplex it using:
but end up with:Code:ffmpeg -y -r 30000/1001 -fflags +genpts -i "J:\tmp\2023-11-24@15_37_21_4710_01.265" -top 0 -metadata encoding_tool="Hybrid 2023.11.24.1" -c:0 copy -map 0:0 -bsf:v hevc_mp4toannexb -tag:v hvc1 -aspect 20:15 -r 30000/1001 -fflags +genpts -f mpegts "G:\Output\bff.m2ts"
FFmpeg version I use is:Code:Input #0, hevc, from 'J:\tmp\2023-11-24@15_18_05_5010_01.265': Duration: N/A, bitrate: N/A Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt470bg/unknown/unknown, top first), 720x480 [SAR 8:9 DAR 4:3], 25 fps, 29.97 tbr, 1200k tbn Output #0, mpegts, to 'G:\Output\bff.m2ts': Metadata: encoder : Lavf60.17.100 Stream #0:0: Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv, bt470bg/unknown/unknown, top first), 720x480 [SAR 8:9 DAR 4:3], q=2-31, 25 fps, 29.97 tbr, 90k tbn Stream mapping: Stream #0:0 -> #0:0 (copy) Press [q] to stop, [?] for help [mpegts @ 000002cecd3a87c0] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly [mpegts @ 000002cecd3a87c0] first pts and dts value must be set [vost#0:0/copy @ 000002cecd38a280] Error submitting a packet to the muxer: Invalid data found when processing input [out#0/mpegts @ 000002cecd2afac0] Error muxing a packet [out#0/mpegts @ 000002cecd2afac0] video:49kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown size= 6kB time=00:00:00.22 bitrate= 223.1kbits/s speed= 346x Conversion failed!
the x265 version I use is:Code:ffmpeg version N-112813-g1c3b13b9f7-gc961ac4b0c+1 Copyright (c) 2000-2023 the FFmpeg developers built with gcc 13.2.0 (Rev2, Built by MSYS2 project) configuration: --pkg-config=pkgconf --cc='ccache gcc' --cxx='ccache g++' --ld='ccache g++' --extra-cxxflags=-fpermissive --extra-cflags=-Wno-int-conversion --disable-autodetect --enable-amf --enable-bzlib --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-iconv --enable-lzma --enable-nvenc --enable-zlib --enable-sdl2 --enable-ffnvcodec --enable-nvdec --enable-cuda-llvm --disable-doc --enable-libmp3lame --enable-libopus --enable-libvorbis --enable-libvpx --enable-libx264 --enable-libx265 --enable-libdav1d --enable-libaom --disable-debug --enable-fontconfig --enable-libass --enable-libbluray --enable-libfreetype --enable-libmfx --enable-libmysofa --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenjpeg --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libwebp --enable-libxml2 --enable-libzimg --enable-libshine --enable-gpl --enable-avisynth --enable-libxvid --enable-libopenmpt --enable-version3 --enable-librav1e --enable-libsrt --enable-libgsm --enable-libvmaf --enable-libsvtav1 --enable-mbedtls --extra-cflags=-DLIBTWOLAME_STATIC --extra-libs=-lstdc++ --extra-cflags=-DLIBXML_STATIC --extra-libs=-liconv --disable-w32threads libavutil 58. 32.100 / 58. 32.100 libavcodec 60. 34.100 / 60. 34.100 libavformat 60. 17.100 / 60. 17.100 libavdevice 60. 4.100 / 60. 4.100 libavfilter 9. 13.100 / 9. 13.100 libswscale 7. 6.100 / 7. 6.100 libswresample 4. 13.100 / 4. 13.100 libpostproc 57. 4.100 / 57. 4.100
Code:x265 [info]: HEVC encoder version 3.5+111-c40c3d799 x265 [info]: build info [Windows][GCC 13.2.0][64 bit] 8bit+10bit+12bit x265 [info]: using cpu capabilities: MMX2 SSE2Fast LZCNT SSSE3 SSE4.2 AVX FMA3 BMI2 AV
A few things bug me:
a. that it's not working
b. that the created video is detected as 'top first' and '25 fps, 29.97 tbr'.
Does anyone know how to fix these to issues?
Cu Selur
Your bff.m2v:
no duration infoStream #0:0: Video: mpeg2video (Main), yuv420p(tv, bottom first), 720x480 [SAR 8:9 DAR 4:3], 25 fps, 29.97 tbr, 1200k tbn
the same, in a mpg container:
duration 05.01Stream #0:0[0x1e0]: Video: mpeg2video (Main), yuv420p(tv, bottom first), 720x480 [SAR 8:9 DAR 4:3], 29.97 fps, 29.97 tbr, 90k tbn
For the muxing of the .265 stream you have to add:
to your commandline.-bsf:v setts=ts=STARTPTS+N/TB_OUT/29.97 -
That seems to help with:
but using:Code:[mpegts @ 000002cecd3a87c0] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly [mpegts @ 000002cecd3a87c0] first pts and dts value must be set
gives me:Code:ffmpeg -y -r 30000/1001 -fflags +genpts -i "J:\tmp\2023-11-24@15_37_21_4710_01.265" -top 0 -metadata encoding_tool="Hybrid 2023.11.24.1" -c:0 copy -map 0:0 -bsf:v hevc_mp4toannexb,setts=ts=STARTPTS+N/TB_OUT/29.97 -tag:v hvc1 -aspect 20:15 -r 30000/1001 -fflags +genpts -f mpegts "G:\Output\bff.m2ts"
Cu SelurCode:Input #0, hevc, from 'J:\tmp\2023-11-24@15_37_21_4710_01.265': Duration: N/A, bitrate: N/A Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt470bg/unknown/unknown, top first), 720x480 [SAR 8:9 DAR 4:3], 25 fps, 29.97 tbr, 1200k tbn [vost#0:0/copy @ 000002598cd9ac00] Overriding aspect ratio with stream copy may produce invalid files Output #0, mpegts, to 'G:\Output\bff.m2ts': Metadata: encoding_tool : Hybrid 2023.11.24.1 encoder : Lavf60.17.100 Stream #0:0: Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv, bt470bg/unknown/unknown, top first), 720x480 [SAR 8:9 DAR 4:3], q=2-31, 25 fps, 29.97 tbr, 90k tbn Stream mapping: Stream #0:0 -> #0:0 (copy) Press [q] to stop, [?] for help [mpegts @ 000002598cd9f380] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly [vost#0:0/copy @ 000002598cd9ac00] Error submitting a packet to the muxer: Invalid argument [out#0/mpegts @ 000002598d07ed00] Error muxing a packet [out#0/mpegts @ 000002598d07ed00] video:49kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown size= 6kB time=00:00:00.26 bitrate= 184.1kbits/s speed= 469x Conversion failed!users currently on my ignore list: deadrats, Stears555, marcorocchini -
My commandline:
converted first to mp4 with:FFmpeg.exe -y -fflags +genpts -i 2023-11-24@15_37_21_4710_01_TSF.mp4 -map 0:0 -c:v copy 2023-11-24@15_37_21_4710_01_TSF_muxed.m2ts
FFmpeg.exe -r 30000/1001 -i 2023-11-24@15_37_21_4710_01_TSF.265 -map 0:0 c:v copy -bsf:v setts=ts=STARTPTS+N/TB_OUT/29.97 2023-11-24@15_37_21_4710_01_TSF.mp4 -
Thanks, but strangely, that does not work here:
fails with:Code:ffmpeg -y -r 30000/1001 -i "J:\tmp\2023-11-24@15_37_21_4710_01.265" -map 0:0 -c:v copy -bsf:v setts=ts=STARTPTS+N/TB_OUT/29.97 "G:\Output\bff.mp4"
will try other ffmpeg versions, maybe its a bug in 'ffmpeg version N-112813-g1c3b13b9f7-gc961ac4b0c+1'.Code:Input #0, hevc, from 'J:\tmp\2023-11-24@15_37_21_4710_01.265': Duration: N/A, bitrate: N/A Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt470bg/unknown/unknown, top first), 720x480 [SAR 8:9 DAR 4:3], 25 fps, 29.97 tbr, 1200k tbn Output #0, mp4, to 'G:\Output\bff.mp4': Metadata: encoder : Lavf60.17.100 Stream #0:0: Video: hevc (Main 10) (hev1 / 0x31766568), yuv420p10le(tv, bt470bg/unknown/unknown, top first), 720x480 [SAR 8:9 DAR 4:3], q=2-31, 25 fps, 29.97 tbr, 30k tbn Stream mapping: Stream #0:0 -> #0:0 (copy) Press [q] to stop, [?] for help [mp4 @ 00000182213988c0] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly [vost#0:0/copy @ 000001821e50e400] Error submitting a packet to the muxer: Invalid argument [out#0/mp4 @ 000001821e509d80] Error muxing a packet [out#0/mp4 @ 000001821e509d80] video:49kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: unknown size= 0kB time=00:00:00.26 bitrate= 7.7kbits/s speed= 473x
Hmm,.. using:
creates an mp4:Code:ffmpeg -y -r 30000/1001 -fflags +genpts -i "J:\tmp\2023-11-24@15_37_21_4710_01.265" -top 0 -metadata encoding_tool="Hybrid 2023.11.24.1" -c:0 copy -map 0:0 -bsf:v hevc_mp4toannexb -tag:v hvc1 -aspect 20:15 -r 30000/1001 "G:\Output\bff.mp4"
Then using:Code:Input #0, hevc, from 'J:\tmp\2023-11-24@15_37_21_4710_01.265': Duration: N/A, bitrate: N/A Stream #0:0: Video: hevc (Main 10), yuv420p10le(tv, bt470bg/unknown/unknown, top first), 720x480 [SAR 8:9 DAR 4:3], 25 fps, 29.97 tbr, 1200k tbn [vost#0:0/copy @ 0000016222e78980] Overriding aspect ratio with stream copy may produce invalid files Output #0, mp4, to 'G:\Output\bff.mp4': Metadata: encoding_tool : Hybrid 2023.11.24.1 encoder : Lavf60.17.100 Stream #0:0: Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv, bt470bg/unknown/unknown, top first), 720x480 [SAR 8:9 DAR 4:3], q=2-31, 25 fps, 29.97 tbr, 30k tbn Stream mapping: Stream #0:0 -> #0:0 (copy) Press [q] to stop, [?] for help [mp4 @ 0000016221d63900] Timestamps are unset in a packet for stream 0. This is deprecated and will stop working in the future. Fix your code to set the timestamps properly [mp4 @ 0000016221d63900] pts has no value Last message repeated 141 times [mp4 @ 0000016221d63900] pts has no value Last message repeated 7 times [out#0/mp4 @ 0000016221c86340] video:2432kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.075280% size= 2434kB time=00:00:04.90 bitrate=4065.5kbits/s speed= 47x
does work:Code:ffmpeg -y -r 30000/1001 -i "G:\Output\bff.mp4" -map 0:0 -c:v copy -bsf:v setts=ts=STARTPTS+N/TB_OUT/29.97 "g:\Output\bff.m2ts"
Thanks.Code:Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'G:\Output\bff.mp4': Metadata: major_brand : isom minor_version : 512 compatible_brands: isomiso2mp41 encoder : Hybrid 2023.11.24.1 Duration: 00:00:04.94, start: 0.000000, bitrate: 4038 kb/s Stream #0:0[0x1](und): Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv, bt470bg/unknown/unknown, top first), 720x480 [SAR 8:9 DAR 4:3], 3981 kb/s, 29.97 fps, 29.97 tbr, 30k tbn (default) Metadata: handler_name : VideoHandler vendor_id : [0][0][0][0] Output #0, mpegts, to 'g:\Output\bff.m2ts': Metadata: major_brand : isom minor_version : 512 compatible_brands: isomiso2mp41 encoder : Lavf60.17.100 Stream #0:0(und): Video: hevc (Main 10) (hvc1 / 0x31637668), yuv420p10le(tv, bt470bg/unknown/unknown, top first), 720x480 [SAR 8:9 DAR 4:3], q=2-31, 3981 kb/s, 29.97 fps, 29.97 tbr, 90k tbn (default) Metadata: handler_name : VideoHandler vendor_id : [0][0][0][0] Stream mapping: Stream #0:0 -> #0:0 (copy) Press [q] to stop, [?] for help [out#0/mpegts @ 000001d95cab9d00] video:2433kB audio:0kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 6.057972% size= 2580kB time=00:00:04.90 bitrate=4309.0kbits/s speed= 941x
Creating an intermedia file makes it unpractical for me, but it's good to know.
Do you have an idea to get ffmpeg to flag it as bff not tff?
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
Why do subs change when encoding to x265?
By Unknown01 in forum Newbie / General discussionsReplies: 6Last Post: 14th Nov 2022, 10:40 -
X265.exe without encoding.
By boohboot in forum Video ConversionReplies: 1Last Post: 10th Apr 2022, 07:49 -
StaxRip issue encoding 4K HDR in x265
By dennisbgi7 in forum Video ConversionReplies: 0Last Post: 12th Mar 2021, 07:44 -
Need Help in x265 Encoding using HandBrake
By FST in forum Newbie / General discussionsReplies: 8Last Post: 27th Jul 2020, 17:36 -
Handbrake x265 encoding cpu doubt
By Sephiroth in forum Video ConversionReplies: 3Last Post: 17th May 2019, 08:29
