Results 1 to 16 of 16
    Nov 2023
    Hello!
    I am hoping you can help, I have received a video that has a file extension MV2.
    I can not find anything that will play the file, I have tried VLC, Windows Media Player and Media Player Classic.
    I just keep getting file not supported.
    Does anyone have any experience with this file type and what software is best to use to play the video?
    Thanks for any help,
  2. Post a mediainfo report (text mode) from this file here.
  3. ^^^This
    Strange. Media Player Classic should be able to open it.
    You could try to rename it as .mpg or m2v and try again ....
    or upload a sample.
    Nov 2023
    Hello, I download MediaInfo but when I opened the file and selected view text. The only info displayed is General, Complete Name and File Size.
    General
    Complete name : C:\Users\DMan\OneDrive\Profile\Desktop\350371 (00-26-4E-10-05-CE)_231103052258_231103064.MV2
    File size : 2.60 GiB
    Nov 2023
    how would I upload a sample? the original file size is 2.6gb.
    Apologies I am naïve when it comes to this
  6. Downloaded crap?
  7. Originally Posted by Deanoliv View Post
    General
    No video file. Could be encrypted.
    Nov 2023
    It is CCTV footage so possibly could be encrypted. Would this mean only selected software will play the file? Is there anyway I can check?
    May 2005
    PAL User
    There are some references to MV2s in Google. "Gotcha" seems to be the program to open the files.
    https://file.org/extension/mv2
    https://forum.ddigest.com/showthread.php?10324 (first post only).
  10. Originally Posted by Deanoliv View Post
    Most probably encrypted, yes. Try to play it back with the same TV/device from which it was recorded.
  11. Member Cornucopia's Avatar
    M2v should be simply the elementary (non-containerized) stream.
    M1v = mpeg 1 video
    M2v = mpeg 2 video
    M4v = mpeg 4 video
    and similarly
    M1a = mpeg 1 audio
    M2a = mpeg 2 audio
    M4a = mpeg 4 audio
    But if Mediainfo doesn't show any stream details, it is very likely either:
    1. Encrypted
    2. Corrupted
    3. Fake
    May 2005
    PAL User
    Scott, it's an MV2.
    Nov 2023
    Thanks again for the help, the footage was supplied by another company, they have sent the file on a CD and a USB stick and both files react the same.
    I believe that they may be encrypted after reading all of your replies. It makes sense
  14. About mv2 see
    https://whatext.com/mv2
    If it is encrypted it doesn't help. If it is not encrypted you can try to extract the video with a trial version of isobuster.
  15. Banned
    Nov 2023
    Europe
    General
    Yeah i was thinking it was encrypted allso!
  16. Member Cornucopia's Avatar
    Shows what happens when you just glance at the OP.
