Hi, does anybody know of a usb HDMI capture card that can be set at 24 fps?
				Results 1 to 13 of 13
	Very unlikely….. better go for a non consumer PCIe HDMI/SDI capture card, (or CamLink dongle ?) there are good cards from BlackmagicDesign, and other brands like that,
 You better explain what you try to do, there might be other/better options available.Last edited by Eric-jan; 25th Nov 2023 at 15:09.
	Just do a google search,i found a 24fps capture device in minutes. I think,therefore i am a hamster.
	The HDMI source could also be a video camera, broadcast transmissions don't do 24fps indeed, one can question if the OP has the right section/forum for his question, so i repeat myself: "You better explain what you are trying to do" this way people here can give better help, the right question will give the right answer, or get pointed in the right direction, capturing here, is mainly about converting analog into digital format, HDMI is already a digital format, which gives also more options to solve, simply by giving more about the setup.
 Magewell capture device:
 https://www.magewell.com/tech-specs/usb-capture-hdmi-plusLast edited by Eric-jan; 25th Nov 2023 at 07:38.
	Are there generic ones like this that are the same device?
 https://www.amazon.com/dp/B0779ZJZX3
	Have you tried searching pricerunner? i tried using google but mostly got results from my own country, i then tried visit https://www.pricerunner.com and searched for USB HDMI Capture Card, it found thousands of products, i didnt check if they had support for 24fps! This website will allso display stores in your country/city/town that can have this part avalible in an store near you, but allso websites that deliver from within your country and such things!
 Edit: If it has support for your country maybe it help make things a lil bit more reliable to use compared to Amazon/E-Bay!
	To support 24p is most of the time a special feature, so i ask again…. for what is it needed ?
 Most USB devices that will support it are expensive, a PCIe card has more bandwith, and has better software support on recent OS's
 [Attachment 75067 - Click to enlarge]
 or try one of these: they come out under different brand names and are real cheap, if that's an important thing for you…google is your friend,
 [Attachment 75068 - Click to enlarge]
 btw… USB capture card = USB dongle/deviceLast edited by Eric-jan; 25th Nov 2023 at 15:19.
	Hi, it's for something I'm testing, which is this:
 https://www.svp-team.com/
 https://bluesky-soft.com/en/BlueskyFRC.html
 http://www.dmitrirender.ru/
 USB would be so I can use it on a laptop.
 If you know of any such capture devices that can be set at 24 fps that would be great if you can post links.
	https://www.amazon.ca/ClonerAlliance-Standalone-Instantly-Recording-Commentary/dp/B08T1PT4P4
 Not sure if it's any good.I think,therefore i am a hamster.
  Is there a USB HDMI capture device that handles 50fps?By AVR2 in forum Capturing and VCRReplies: 3Last Post: 4th Jun 2023, 21:47
  Tevion USB capture card not recognized (shows USB 2861 Video)By retractOffer in forum Capturing and VCRReplies: 3Last Post: 4th Mar 2023, 12:38
  HDMI USB Capture with 576i (uncompressed) supportBy slikvik in forum Capturing and VCRReplies: 32Last Post: 15th Jun 2022, 02:49
  Cable box > HDMI audio receiver > HDMI splitter > Capture card?By ArianK in forum AudioReplies: 0Last Post: 6th May 2021, 04:18
  TV Receiver ( Set-Top Box ) with Conax card reader, HDMI IN and SCART OUT ?By Rytis Jonas in forum DVB / IPTVReplies: 1Last Post: 22nd Oct 2020, 21:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
