Hi, this is my first post, I'm sorry if this has been discossed before but I can't find an answer anywhere, firts some background:
I use my usb's bluray player port to play almost everything I download. For years the movies and series in MKV have been played fine. I canīt play audio at EAC but I convert everything using EAC to UsEac3 and works great.
Anyway, whit recent downloads I have noticed that some latest movies or series come at 23,976 fps and my player can't play that as usuall, the video frezes every 2 o 3 seconds, is very frustrating to watch a complete movie like that. I tried to force the 24fps using MKVToolNix and it works, but then as the movie goes the audio starts to get out of sync, I supossed this is logic since I am forcing the video to 24fps but not the audio.
So here is my question, is there any way to solve this using some other software? or, can I fix it at MKVToolNix somehow?
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Probably incompatible video profile, video settings, or codec for your BD player.
You can use mediainfo (view=>text) to examine characteristics of some of the ones that have problems .
You might have to re-encode using compatible settings for it to play correctly on the player .
First verify that the files play correctly in a software player on a computer, like MPCHC, VLC, etc...
Interpolate a video from 23.976fps to 71.928fps or 60fps?
By Platos in forum Newbie / General discussionsReplies: 23Last Post: 5th Oct 2023, 14:36 -
What is a good way to convert from 29.97fps to 23.976fps?
By jsj2251 in forum Video ConversionReplies: 15Last Post: 28th Apr 2022, 07:54 -
29.97 fps to 23.976fps audio with length different
By ChampaRando in forum Video ConversionReplies: 19Last Post: 26th Nov 2020, 16:10 -
Decimate anime to 23.976fps or keep 29.97fps?
By killerteengohan in forum Newbie / General discussionsReplies: 1Last Post: 15th Jun 2020, 23:08 -
Problem opening security camera video files
By astute in forum MacReplies: 8Last Post: 2nd Apr 2020, 17:15
