Hi,
Maybe I'm doing something stupid but I would like to record a RTSP Stream and be able to replay it with the same absolute date.
Let's say that if I record the stream today 22 November 15h11.
I would like that the timestamp information to be save in the video container and to be able to be replay with the same date at the ~same speed.
Do you know some video container that would be suitable for this usecase?
Thanks for your help
	Is it not possible to just add this date into the video tags/meta data? i dont really know what an RTSP stream is but allso there is programs to customize the file date stamps directly to an file!
 Edit: And isnt there an setting "Set default playback speed" allso ? which this allso get saved into the meta data/video tags thing or somewhere close to it!Last edited by Swedaniel; 22nd Nov 2023 at 09:31.
	Thanks for your reply,
 However this imply that the playback speed is constant, and that there is no lost frames no ?
  Keeping timestamp of edited / converted VideoBy keyboard in forum Newbie / General discussionsReplies: 5Last Post: 30th Apr 2024, 01:10
  Extract multiple video tracks from one video container.By Russai in forum Newbie / General discussionsReplies: 3Last Post: 29th Jul 2023, 09:07
  Remove timestampBy Rockel83 in forum EditingReplies: 171Last Post: 15th Jan 2023, 20:43
  timestamp oddities - help to fixBy Quoddity in forum Newbie / General discussionsReplies: 1Last Post: 3rd Jan 2023, 06:27
  Best codec and container format for specific need (home video)By nckhrs in forum Video ConversionReplies: 35Last Post: 30th Dec 2018, 01:20
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
