I have many 8mm cassette tapes that I need to digitize, My camcorder DCR-TRV480 is operable. What cable do I need to digitize to computer. There are 3 types of connections to choose from. Which is best and where do I find?
S-Video is the best output to capture from using a USB capture device, If your camcorder is not equipped with S-Video your second best option is iLink and capture to lossy DV, you will have to have a firewire card installed on your computer, Lastly the worst option is capture from composite.
My camcorder has 3 outputs for transferring video or pics. 1: A/V jack 2: iLink interface jack and 3: a mini-USB
The mini-USB apparently is not for video, just pic from what I've read. I think my route is the iLink interface however my computer does not have a card for it. I need something in between. -
Buy a Firewire expansion card, they are less than $10 on eBay. No reason to ruin your Digital8 recordings with converting to analog, sending it as composite, and converting back to digital.
Make sure you have an empty PCIE slot in your computer. Your can get a firewire card from online store like this one.
https://www.amazon.com/Padarsey-Firewire-Windows-Express-Controller/dp/B08SC477FN/ref=...%2C301&sr=8-11
Once the connection is up, use ScenalyzerLive to transfer your video on tape to computer in DV format. This is a Windows standard format and you don't need to install any codec. -
How to Digitize 8mm from an old Hitachi Camcorder?
By Davis White in forum Newbie / General discussionsReplies: 2Last Post: 28th Jun 2022, 00:51 -
have a old Samsung dtb-p770v with íde hard drive. Copy hard-drive?
By OldSchool297 in forum DVD & Blu-ray RecordersReplies: 8Last Post: 28th Apr 2022, 03:12 -
"Honestech VHStoDVD Deluxe 8" Shaky video transfer-8mm camcorder cassettes
By Edna Oomen in forum Newbie / General discussionsReplies: 1Last Post: 27th Feb 2021, 15:31 -
Transferring 8mm cassette footage to my computer?
By maxton in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 24th Mar 2020, 13:12 -
Trying to convert old 8mm video cassettes to digital
By Billymax in forum Newbie / General discussionsReplies: 11Last Post: 16th Aug 2019, 06:19
