when i play a vcd in my dvd its stops at each chapter, someone said you must join the 5 dat files, what is the best way to do this, because i aint gotta clue
This is how I should do it:
Copy the *DAT files to your harddrive.
Rename them to: xxxxxx.mpg
Add the Mpegs together with TMPGEnc
now you will have one big Mpeg file.
Burn it as a VCD
DoneThe Dutchman -
You should convert your dat files to mpeg by a program named vcdgear or something else.
Dat files are different from mpeg and so they're not converted to mpeg by renaming. After convertion, mpeg files can be joined by many editing programs such as mpeg tools of tmpgenc but for a precise and frame accurate cut or join tmpgenc is not recommended at all.
A chapter is not a track, a pause between tracks is normal but interruption at chapters is a problam of your player.
You could have many chapters on a vcd but one track(dat file). You can burn your ripped mpeg as a vcd without chapters.
Player needs dat. file of avi files on disk
By karadeano in forum LinuxReplies: 9Last Post: 27th Jul 2015, 09:39 -
VCD dat files
By mayflower in forum Newbie / General discussionsReplies: 1Last Post: 18th Mar 2009, 07:50 -
Advice needed on copying .dat files to DVD discs
By laval_ng in forum Video ConversionReplies: 17Last Post: 25th Oct 2008, 01:30 -
Do Divx dvd players play dat files?
By neo76 in forum DVD & Blu-ray PlayersReplies: 9Last Post: 23rd Oct 2008, 22:27 -
How to create dat files?
By dimtim in forum ComputerReplies: 8Last Post: 6th Aug 2007, 08:03
