I used X264 lossless to record a video tape as a test, and even though my CPU usage was always under 13% and I had 0 dropped frames, when I watched the video after there is stuttering non stop. If it's true that Huffyuv prevents dropped frames that VirtualDub doesn't report, does Lagarith do the same thing? Getting VirtualDub to recognise Huffyuv in Windows 10 is very difficult.
"Stuttering non stop" , as in (forward/back/forward/back) suggests wrong field order during playback, not dropped frames
If you open the capture back in vdub2, apply deinterlace => yadif => double frame rate => top field first => apply and preview , is it smooth ? If not, try bottom field first -
To answer your question, most probably not. Dropped frames are caused by your capture workflow hardware; a wonky signal coming off the tape (dodgy VCR or recording), lack of a stabiliser/TBC and/or a shonky digitiser.
HUFF is a pain to set up in Windows. Have a look at Hofmand's setup process on Github.
Or there are other good lossless options: LAGS (you've already mentioned); UT video or if you are happy to pay a few dollars, MagicYUV. -
Deleted
By KhAoS182 in forum Capturing and VCRReplies: 5Last Post: 22nd Sep 2022, 06:12 -
What are inserted frames in Virtualdub when recording VHS?
By bigbadben in forum Newbie / General discussionsReplies: 11Last Post: 17th Nov 2021, 10:01 -
Dropped Frames?
By Craft in forum EditingReplies: 3Last Post: 13th Apr 2021, 12:05 -
How do you know the cause of dropped frames capturing VHS?
By bigbadben in forum Newbie / General discussionsReplies: 3Last Post: 18th Oct 2020, 08:54 -
25fps with duplicates and dropped frames
By embis2003 in forum RestorationReplies: 6Last Post: 12th Oct 2020, 01:43
