Using Get_Iplayer to download this
https://www.bbc.co.uk/iplayer/episode/m001sgb2/bbc-children-in-need-2023-live-show
Using "fhd" in the command gives me an error stating that this quality is not available. When I change the command to "hd" I can only get the 720p video.
I suspect that I'm missing something because it's unlikely that such a recent broadcast isn't available in 1080p. Can you have a look and let me know what's up? Thanks
				Results 1 to 30 of 31
	You can get 1080p from there
 https://forum.videohelp.com/threads/411643-Freevine-A-downloader-for-free-streaming-services
 and can get up to 2160p from vinetrimmer
	Thanks a lot. It's working now. Apparently I need to wait a few hours after live broadcasts for the FHD version to be available
	Fantastic! Thank you. Do you know by the way if BBC upscales the 720p video to create a 1080p one? Some times I compare the exact frames from both 720p and 1080p videos and get the feeling that there is no new "information" or actual gain in detail. Seems like the 720p video is just enlarged.
	I don't personally know for sure, but if I were them I would use the broadcast video to encode 720p and 1080p from, I certainly wouldn't upscale them. Maybe the 720p is ready faster as the encode is a lot faster and they can encode it on the fly. I'm only guessing though.
	Edit: I might have been mistaken. Need more testing Last edited by adrian44; 18th Nov 2023 at 10:48.
	you can see 4k 2160p planet earth 3 from iplayer
 [Attachment 74935 - Click to enlarge]
	why would you need it for? its old, most of services wont work. it havent been update
 [Attachment 75791 - Click to enlarge]
	I see. I had a look into downloading it in the past, and I found a list of certs that the server accepted, but I couldn't find any certs floating around on the internet.
 Since there's no eta on 4k support through freevine, I'll try to see if I can find the list again and we can see if it is possible to create a simple downloader, as all bbc streams are unencrypted.
 edited to remove incorrect reference to wireshark.Last edited by stupid.345; 28th Dec 2023 at 06:09.
	hi there again - I have reconstructed the command to see certs the server will accept
 Code:openssl s_client -showcerts -connect securegate.iplayer.bbc.co.uk:443
	@iamghost If you have free time, please may you tell me where I could get a version of vinetrimmer that work for iplayer in 4k?
	Thank you so much for your quick reply, and sorry I did not see until today. I had a strange issue that I cannot seem to resolve this error. Is it fixable, or do I just need to move on? I am running Linux.
 Code:USER@HOSTNAME ~/Documents/plex/VT$ poetry run vt dl -w S01E01 ip p04tjbtx 1 ↵ ✹main 2023-12-31 23:04:09 [I] root : Vinetrimmer version 0.0.7 Copyright (c) 2019-2021 the Vinetrimmer Contributors 2023-12-31 23:04:09 [I] root : Convenient Widevine-DRM Downloader and Decrypter. 2023-12-31 23:04:09 [I] root : https://github.com/rlaphoenix/vinetrimmer 2023-12-31 23:04:09 [I] root : [Root Config] : /home/USER/.config/vinetrimmer/vinetrimmer.toml 2023-12-31 23:04:09 [I] root : [Service Configs] : /home/USER/.config/vinetrimmer/Services 2023-12-31 23:04:09 [I] root : [Cookies] : /home/USER/.local/share/vinetrimmer/Cookies 2023-12-31 23:04:09 [I] root : [WVDs] : /home/USER/.local/share/vinetrimmer/WVDs 2023-12-31 23:04:09 [I] root : [Cache] : /home/USER/.cache/vinetrimmer 2023-12-31 23:04:09 [I] root : [Logs] : /home/USER/.cache/vinetrimmer/log 2023-12-31 23:04:09 [I] root : [Temp Files] : /var/tmp/vinetrimmer 2023-12-31 23:04:09 [I] root : [Downloads] : /home/USER/Downloads/vinetrimmer 2023-12-31 23:04:09 [I] download : + 0 Local Vaults 2023-12-31 23:04:09 [I] download : + 0 Remote Vaults 2023-12-31 23:04:09 [I] download : + Loaded LocalDevice: 4464 (L3) 2023-12-31 23:04:09 [I] iP : Creating a Python-requests Session 2023-12-31 23:04:09 [I] iP : + Set Common Headers 2023-12-31 23:04:09 [I] iP : + Set Cookies 2023-12-31 23:04:09 [I] iP : + Loaded [BBCiPlayer] Class instance 2023-12-31 23:04:09 [I] iP : Retrieving Titles Traceback (most recent call last): File "<string>", line 1, in <module> File "/home/USER/.cache/pypoetry/virtualenvs/vinetrimmer-yiuEISbQ-py3.11/lib/python3.11/site-packages/click/core.py", line 1157, in __call__ return self.main(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/USER/.cache/pypoetry/virtualenvs/vinetrimmer-yiuEISbQ-py3.11/lib/python3.11/site-packages/click/core.py", line 1078, in main rv = self.invoke(ctx) ^^^^^^^^^^^^^^^^ File "/home/USER/.cache/pypoetry/virtualenvs/vinetrimmer-yiuEISbQ-py3.11/lib/python3.11/site-packages/click/core.py", line 1688, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/USER/.cache/pypoetry/virtualenvs/vinetrimmer-yiuEISbQ-py3.11/lib/python3.11/site-packages/click/core.py", line 1688, in invoke return _process_result(sub_ctx.command.invoke(sub_ctx)) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/USER/.cache/pypoetry/virtualenvs/vinetrimmer-yiuEISbQ-py3.11/lib/python3.11/site-packages/click/core.py", line 1657, in _process_result value = ctx.invoke(self._result_callback, value, **ctx.params) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/USER/.cache/pypoetry/virtualenvs/vinetrimmer-yiuEISbQ-py3.11/lib/python3.11/site-packages/click/core.py", line 783, in invoke return __callback(*args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/USER/.cache/pypoetry/virtualenvs/vinetrimmer-yiuEISbQ-py3.11/lib/python3.11/site-packages/click/decorators.py", line 33, in new_func return f(get_current_context(), *args, **kwargs) ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^ File "/home/USER/Documents/plex/VT/vinetrimmer/commands/dl.py", line 252, in result titles = Titles(as_list(service.get_titles())) ^^^^^^^^^^^^^^^^^^^^ File "/home/USER/Documents/plex/VT/vinetrimmer/services/bbciplayer.py", line 77, in get_titles for season in r["slices"]: TypeError: 'NoneType' object is not iterable USER@HOSTNAME ~/Documents/plex/VT$
	Code:2023-12-31 22:16:12 [I] download : + 1 Local Vaults 2023-12-31 22:16:12 [I] download : + 0 Remote Vaults 2023-12-31 22:16:12 [I] download : + Loaded LocalDevice: 4464 (L3) 2023-12-31 22:16:12 [I] iP : Creating a Python-requests Session 2023-12-31 22:16:12 [I] iP : + Set Common Headers 2023-12-31 22:16:12 [I] iP : + Set Cookies 2023-12-31 22:16:12 [I] iP : Obtaining a proxy to "gb" 2023-12-31 22:16:13 [I] iP : + Proxy was skipped as current region matches 2023-12-31 22:16:13 [I] iP : + Loaded [BBCiPlayer] Class instance 2023-12-31 22:16:13 [I] iP : Retrieving Titles 2023-12-31 22:16:13 [I] Titles : Title: Blue Planet II 2023-12-31 22:16:13 [I] Titles : Total Episodes: 8 2023-12-31 22:16:13 [I] Titles : By Season: 0 (1), 1 (7) 2023-12-31 22:16:13 [I] iP : Getting tracks for Blue Planet II S00E00 - Oceans of Wonder 2023-12-31 22:16:14 [I] iP : > All Tracks: 2023-12-31 22:16:14 [I] Tracks : 12 Video Tracks: 2023-12-31 22:16:14 [I] Tracks : VID | [avc1.64002A, SDR] | en | 1920x1080 @ 12000 kb/s, 50.000 FPS 2023-12-31 22:16:14 [I] Tracks : VID | [avc1.640020, SDR] | en | 1280x720 @ 5070 kb/s, 50.000 FPS 2023-12-31 22:16:14 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 2812 kb/s, 50.000 FPS 2023-12-31 22:16:14 [I] Tracks : VID | [avc1.64001F, SDR] | en | 960x540 @ 1604 kb/s, 50.000 FPS
	ip = service- iplayer
 p04tjbtx = iplayer programmes ID
 -w = want season# episode#
 -sl = subtitle language
 -l = audio lanuage
 read readme.txt they tell you how to use with services list
  recent menu change cuts off textBy Skaperen in forum FeedbackReplies: 2Last Post: 21st Nov 2021, 19:13
  Recent channel 9 issue multiple filesBy vur in forum Newbie / General discussionsReplies: 6Last Post: 13th May 2021, 03:44
  Any *recent* info on Skystream ?By Seeker47 in forum Video Streaming DownloadingReplies: 4Last Post: 22nd Apr 2021, 03:51
  Canopus advc 100 on a recent LaptopBy mohamed in forum Capturing and VCRReplies: 5Last Post: 11th Feb 2020, 14:07
  Converting a 1080p 60Hz to 1080p 23.97HzBy snadge in forum Video ConversionReplies: 3Last Post: 11th Sep 2019, 12:31
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
