Hi experts, I recently picked up a cheap NV-HS860 which seems to be fairly well rated on here. Apparently this one was in storage and not used for a long long time.
I've taken some photos of the internals and want to clean it up before I try any tapes. What can I read into the condition of it? There seems to be a dark grease which still looks "wet". There is some yellow gunk - is this some sort of grease also?
Really keen to understand what I should be cleaning here, do i remove all dark and yellow lubricants and regrease, can I tell anything of the head conditions from a visual check? Is q-tips for general cleaning with rubbing alcohol fine, and use the paper trick for the head cleaning?
Photos/video here - https://1drv.ms/f/s!AoYVwYm0qHh9lsRuI0Ujb4J7ewnJtQ?e=G8s1z4
Remove all grease, put some new, clean heads (paper + iso alcohol method),drum, tape path. Put some oil at the base of the motor shaft last but not least clean the mode switch (to prevent things like won't fast forward/rewind, tape eject directly) that's the gist of it
*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
If the grease is still fine and not dried or missing or something I don't know if it's worth removing and reapplying, it's not a type that's known for drying up or anything. Most critical parts that can cause issues on this mech as far as I know in a few cases are the worm gear coupling and the gears moving the tape guides so most important to make sure those are well lubricated.
The state of the head cleaning brush thing can be an indication of how much use it's seen. It doesn't look overly worn or anything at least.
Panasonic NV-HS860 Desaturates Colours. How to fix it?
By Master Tape in forum RestorationReplies: 8Last Post: 7th Nov 2023, 22:14 -
How to get the good pssh and then the good key.
By abacaxi in forum Video Streaming DownloadingReplies: 16Last Post: 13th May 2023, 09:14 -
Panasonic FS-88
By phelissimo_ in forum Capturing and VCRReplies: 8Last Post: 21st Dec 2022, 09:00 -
Need help with Panasonic AG-1970
By Crockett1984 in forum RestorationReplies: 8Last Post: 18th Nov 2022, 10:40 -
Panasonic NV-HS860 strange pictue/sync problem
By gargap in forum RestorationReplies: 0Last Post: 28th Oct 2020, 03:09
