I'm trying to convert a video from 29 fps to 59 with ChangeFPS (to make it fluid and smooth) in Avisynth, but the result of the video is completely accelerated, could anyone help me with a script for this?
Results 1 to 13 of 13
Before changefps("ntsc_double") put a line above it with assumefps("ntsc_video"). If the video is vfr it will lose sync but for cfr wit should work fine.
if all else fails read the manual -
ChangeFPS should normally decimate/repeat frames to give the new rate. It wouldn't change the
speed, nor would it make motion look any smoother -
What is your entire script?
SetFilterMTMode ("QTGMC", 2)
FFMPEGSource2("video.avi", atrack=-1)
ConverttoYV12()
temporaldegrain()
FineSharp()
Sharpen(0.2)
aWarpSharp(depth=03)
deflicker()
DeScratch(mindif=5, asym=10, maxgap=3, maxwidth=3, minlen=90, maxlen=2048, maxangle=5, blurlen=15, keep=30, border=2, modeY=3, modeU=3, modeV=3, mindifUV=0, mark=false, minwidth=1)
TTempSmooth()
Lanczos4Resize(1920,1080) -
If your video is interlaced you can just bob-deinterlace it
If it is progressive you would have to apply a temporal interpolator, like FrameRateConverter or RIFECode:AssumeTFF() #or BFF if the source is bottom field first QTGMC() #or use a bobber of your choice
Are you sure it is progressive? Or is it telecined film? If so you would have to IVTC (Inverse Telecine) it at first.
For framerate conversion see:
http://avisynth.nl/index.php/FrameRateConverter
http://avisynth.nl/index.php/RIFELast edited by Sharc; 17th Nov 2023 at 09:42.
Some comments on your script, as you were asking help on YouTubeFFMPEGSource2("video.avi", atrack=-1)
ConverttoYV12()
temporaldegrain()
FineSharp()
Sharpen(0.2)
deflicker()
TTempSmooth()
- DeFlicker should be first
- DeScratch should be second
- TemporalDegrain and TTempSmooth are similar. Use just one, for example TemporalDegrain2 with TR=3
- 3 different sharpeners to obtain what?
- Lanczos4Resize can be replaced by Nnedi3
- sharpen after denoise
- sharpen before of after upscale according to your source and preference
Audio from 25 fps in 23,976 fps video always out of sync even if converted
By Huggy in forum AudioReplies: 5Last Post: 2nd May 2023, 05:05 -
Change FPS playback speed of mp4 Video without converting it
By DReffects in forum Video ConversionReplies: 2Last Post: 19th Apr 2022, 15:33 -
VSDC - Playback Issues With Sped Up Video
By JonathanStone in forum EditingReplies: 0Last Post: 26th Jan 2022, 17:50 -
Reboot: would TBC help converting old VHS cam vids w sped-up voices?
By LouGee in forum Video ConversionReplies: 0Last Post: 3rd May 2020, 14:04 -
How to Voice over a video section that is sped up and/or split?
By DataDude in forum Newbie / General discussionsReplies: 4Last Post: 17th Mar 2020, 07:39
