Hi guys,
I've run into a bit of annoying issue with Plex and my AppleTV. Whenever I try to play a video with HDR10+, the video doesn't play. But if the video uses regular HDR10, it plays just fine. From what I can see, this is a known issue with Plex, and doesn't seem like it will be fixed soon. Yes, HDR10+ is supposed to automatically fall back to HDR10 if HDR10+ isn't supported, but for whatever reason, Plex doesn't do that. What I'd like to do is convert any HDR10+ videos I have to use HDR10 instead. That will keep Plex happy and I can still watch HDR videos in HDR. My TV doesn't support HDR10+ anyway, so I don't mind that I'm losing out on it.
I'm not sure how complicated this would be, but from my understanding, HDR10+ is just metadata in the video file, which sounds like it wouldn't be necessary to re-encode the video..? Does anyone have any suggestions?
HDR-10 is just a bunch of tags.
HDR-10+ additionally adds (potentially per frame) adjustments.
=> HDR10+ is really just HDR-10 with dynamic metadata
https://forum.doom9.org/showthread.php?t=181702 might be helpful to remove the extra data.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
Removing HDR10+ metadata from a HDR10 encoded hevc stream can easily be done with quietvoid's hdr10plus tool.
Example:
Code:hdr10plus_tool remove video.hevc -o hdr10plus_removed_output.hevc
Download at https://github.com/quietvoid/hdr10plus_tool
Help me for HDR10 4K encoding
By doostanehsoft in forum Video ConversionReplies: 15Last Post: 9th Mar 2023, 07:16 -
HD to UHD HDR10?
By meimeiriver in forum Newbie / General discussionsReplies: 6Last Post: 5th Feb 2022, 07:21 -
Possible to convert HDR10 to HDR10+?
By ShikuTeshi in forum Video ConversionReplies: 8Last Post: 18th Jan 2022, 15:31 -
4K HDR10 > FHD HDR10 weights less than 4K HDR10 > FHD SDR ????
By bokeron2020 in forum Video ConversionReplies: 17Last Post: 17th Aug 2021, 21:47 -
HDR10 not working?
By Mikami in forum Video ConversionReplies: 7Last Post: 12th May 2019, 20:46
