Hi Folks,
I have a question, is it possible to play drm protected streams with enigma2 linux reciever? i have installed ffmpeg from the feed. its configured with te following options:
But i get the following error:configuration: --enable-nonfree --cross-prefix=arm-oe-linux-gnueabi- --ld='arm-oe-linux-gnueabi-gcc -mfpu=neon-vfpv4 -mfloat-abi=hard -mcpu=cortex-a15 --sysroot=/openpli/oe/release-8.3/build/tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/ffmpeg/4.4.1-r0/recipe-sysroot' --cc='arm-oe-linux-gnueabi-gcc -mfpu=neon-vfpv4 -mfloat-abi=hard -mcpu=cortex-a15 --sysroot=/openpli/oe/release-8.3/build/tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/ffmpeg/4.4.1-r0/recipe-sysroot' --cxx='arm-oe-linux-gnueabi-g++ -mfpu=neon-vfpv4 -mfloat-abi=hard -mcpu=cortex-a15 --sysroot=/openpli/oe/release-8.3/build/tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/ffmpeg/4.4.1-r0/recipe-sysroot' --arch=arm --target-os=linux --enable-cross-compile --extra-cflags=' -Os -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/openpli/oe/release-8.3/build/tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/ffmpeg/4.4.1-r0=/usr/src/debug/ffmpeg/4.4.1-r0 -fdebug-prefix-map=/openpli/oe/release-8.3/build/tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/ffmpeg/4.4.1-r0=/usr/src/debug/ffmpeg/4.4.1-r0 -fdebug-prefix-map=/openpli/oe/release-8.3/build/tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/ffmpeg/4.4.1-r0/recipe-sysroot= -fdebug-prefix-map=/openpli/oe/release-8.3/build/tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/ffmpeg/4.4.1-r0/recipe-sysroot-native= -mfpu=neon-vfpv4 -mfloat-abi=hard -mcpu=cortex-a15 --sysroot=/openpli/oe/release-8.3/build/tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/ffmpeg/4.4.1-r0/recipe-sysroot' --extra-ldflags='-Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed' --sysroot=/openpli/oe/release-8.3/build/tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/ffmpeg/4.4.1-r0/recipe-sysroot --prefix=/usr --disable-runtime-cpudetect --disable-ffplay --enable-ffprobe --disable-doc --disable-htmlpages --disable-manpages --disable-podpages --disable-txtpages --disable-altivec --disable-amd3dnow --disable-amd3dnowext --disable-mmx --disable-mmxext --disable-sse --disable-sse2 --disable-sse3 --disable-ssse3 --disable-sse4 --disable-sse42 --disable-avx --disable-xop --disable-fma3 --disable-fma4 --disable-avx2 --disable-inline-asm --disable-yasm --disable-x86asm --disable-fast-unaligned --disable-dxva2 --disable-vaapi --disable-vdpau --disable-muxers --enable-muxer=apng --enable-muxer=flac --enable-muxer=mp3 --enable-muxer=h261 --enable-muxer=h263 --enable-muxer=h264 --enable-muxer=h265 --enable-muxer=hevc --enable-muxer=image2 --enable-muxer=image2pipe --enable-muxer=m4v --enable-muxer=matroska --enable-muxer=mjpeg --enable-muxer=mp4 --enable-muxer=mpeg1video --enable-muxer=mpeg2video --enable-muxer=mpegts --enable-muxer=ogg --disable-parsers --enable-parser=aac --enable-parser=aac_latm --enable-parser=ac3 --enable-parser=dca --enable-parser=dvbsub --enable-parser=dvd_nav --enable-parser=dvdsub --enable-parser=flac --enable-parser=h264 --enable-parser=h265 --enable-parser=hevc --enable-parser=mjpeg --enable-parser=mpeg4video --enable-parser=mpegvideo --enable-parser=mpegaudio --enable-parser=png --enable-parser=vc1 --enable-parser=vorbis --enable-parser=vp8 --enable-parser=vp9 --disable-encoders --enable-encoder=aac --enable-encoder=h261 --enable-encoder=h263 --enable-encoder=h263p --enable-encoder=jpeg2000 --enable-encoder=jpegls --enable-encoder=ljpeg --enable-encoder=libx264 --enable-encoder=mjpeg --enable-encoder=mpeg1video --enable-encoder=mpeg2video --enable-encoder=mpeg4 --enable-encoder=png --enable-encoder=rawvideo --disable-decoders --enable-decoder=aac --enable-decoder=aac_latm --enable-decoder=adpcm_ct --enable-decoder=adpcm_g722 --enable-decoder=adpcm_g726 --enable-decoder=adpcm_g726le --enable-decoder=adpcm_ima_amv --enable-decoder=adpcm_ima_oki --enable-decoder=adpcm_ima_qt --enable-decoder=adpcm_ima_rad --enable-decoder=adpcm_ima_wav --enable-decoder=adpcm_ms --enable-decoder=adpcm_sbpro_2 --enable-decoder=adpcm_sbpro_3 --enable-decoder=adpcm_sbpro_4 --enable-decoder=adpcm_swf --enable-decoder=adpcm_yamaha --enable-decoder=alac --enable-decoder=ape --enable-decoder=atrac1 --enable-decoder=atrac3 --enable-decoder=atrac3p --enable-decoder=ass --enable-decoder=cook --enable-decoder=dca --enable-decoder=dsd_lsbf --enable-decoder=dsd_lsbf_planar --enable-decoder=dsd_msbf --enable-decoder=dsd_msbf_planar --enable-decoder=dvbsub --enable-decoder=dvdsub --enable-decoder=eac3 --enable-decoder=evrc --enable-decoder=flac --enable-decoder=g723_1 --enable-decoder=g729 --enable-decoder=h261 --enable-decoder=h263 --enable-decoder=h263i --enable-decoder=h264 --enable-decoder=h264_v4l2m2m --enable-decoder=h265 --enable-decoder=hevc --enable-decoder=hevc_v4l2m2m --enable-decoder=iac --enable-decoder=imc --enable-decoder=jpeg2000 --enable-decoder=jpegls --enable-decoder=mace3 --enable-decoder=mace6 --enable-decoder=metasound --enable-decoder=mjpeg --enable-decoder=mlp --enable-decoder=movtext --enable-decoder=mp1 --enable-decoder=mp2 --enable-decoder=mp3 --enable-decoder=mp3adu --enable-decoder=mp3on4 --enable-decoder=mpeg1video --enable-decoder=mpeg2video --enable-decoder=mpeg4 --enable-decoder=nellymoser --enable-decoder=opus --enable-decoder=pcm_alaw --enable-decoder=pcm_bluray --enable-decoder=pcm_dvd --enable-decoder=pcm_f32be --enable-decoder=pcm_f32le --enable-decoder=pcm_f64be --enable-decoder=pcm_f64le --enable-decoder=pcm_lxf --enable-decoder=pcm_mulaw --enable-decoder=pcm_s16be --enable-decoder=pcm_s16be_planar --enable-decoder=pcm_s16le --enable-decoder=pcm_s16le_planar --enable-decoder=pcm_s24be --enable-decoder=pcm_s24daud --enable-decoder=pcm_s24le --enable-decoder=pcm_s24le_planar --enable-decoder=pcm_s32be --enable-decoder=pcm_s32le --enable-decoder=pcm_s32le_planar --enable-decoder=pcm_s8 --enable-decoder=pcm_s8_planar --enable-decoder=pcm_u16be --enable-decoder=pcm_u16le --enable-decoder=pcm_u24be --enable-decoder=pcm_u24le --enable-decoder=pcm_u32be --enable-decoder=pcm_u32le --enable-decoder=pcm_u8 --enable-decoder=pcm_zork --enable-decoder=pgssub --enable-decoder=png --enable-decoder=qcelp --enable-decoder=qdm2 --enable-decoder=ra_144 --enable-decoder=ra_288 --enable-decoder=ralf --enable-decoder=s302m --enable-decoder=sipr --enable-decoder=shorten --enable-decoder=sonic --enable-decoder=srt --enable-decoder=ssa --enable-decoder=subrip --enable-decoder=subviewer --enable-decoder=subviewer1 --enable-decoder=tak --enable-decoder=text --enable-decoder=truehd --enable-decoder=truespeech --enable-decoder=tta --enable-decoder=vorbis --enable-decoder=vp9_v4l2m2m --enable-decoder=wmalossless --enable-decoder=wmapro --enable-decoder=wmav1 --enable-decoder=wmav2 --enable-decoder=wmavoice --enable-decoder=wavpack --enable-decoder=xsub --disable-demuxers --enable-demuxer=aac --enable-demuxer=ac3 --enable-demuxer=apng --enable-demuxer=ass --enable-demuxer=avi --enable-demuxer=dts --enable-demuxer=dash --enable-demuxer=ffmetadata --enable-demuxer=flac --enable-demuxer=flv --enable-demuxer=h264 --enable-demuxer=h265 --enable-demuxer=hls --enable-demuxer=image2 --enable-demuxer=image2pipe --enable-demuxer=image_bmp_pipe --enable-demuxer=image_jpeg_pipe --enable-demuxer=image_jpegls_pipe --enable-demuxer=image_png_pipe --enable-demuxer=m4v --enable-demuxer=matroska --enable-demuxer=mjpeg --enable-demuxer=mov --enable-demuxer=mp3 --enable-demuxer=mpegts --enable-demuxer=mpegtsraw --enable-demuxer=mpegps --enable-demuxer=mpegvideo --enable-demuxer=mpjpeg --enable-demuxer=ogg --enable-demuxer=pcm_s16be --enable-demuxer=pcm_s16le --enable-demuxer=realtext --enable-demuxer=rawvideo --enable-demuxer=rm --enable-demuxer=rtp --enable-demuxer=rtsp --enable-demuxer=srt --enable-demuxer=vc1 --enable-demuxer=wav --enable-demuxer=webm_dash_manifest --disable-filters --enable-filter=scale --enable-filter=drawtext --enable-filter=overlay --enable-zlib --enable-bzlib --enable-openssl --enable-libass --enable-bsfs --disable-xlib --disable-libxcb --disable-libxcb-shm --disable-libxcb-xfixes --disable-libxcb-shape --enable-shared --enable-network --enable-nonfree --enable-small --enable-stripping --disable-static --disable-debug --disable-runtime-cpudetect --enable-pic --enable-pthreads --enable-hardcoded-tables --enable-armv6 --enable-armv6t2 --enable-vfp --enable-neon --extra-cflags=' -Os -pipe -g -feliminate-unused-debug-types -fmacro-prefix-map=/openpli/oe/release-8.3/build/tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/ffmpeg/4.4.1-r0=/usr/src/debug/ffmpeg/4.4.1-r0 -fdebug-prefix-map=/openpli/oe/release-8.3/build/tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/ffmpeg/4.4.1-r0=/usr/src/debug/ffmpeg/4.4.1-r0 -fdebug-prefix-map=/openpli/oe/release-8.3/build/tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/ffmpeg/4.4.1-r0/recipe-sysroot= -fdebug-prefix-map=/openpli/oe/release-8.3/build/tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/ffmpeg/4.4.1-r0/recipe-sysroot-native= -mfpu=neon-vfpv4 -mfloat-abi=hard -mcpu=cortex-a15 --sysroot=/openpli/oe/release-8.3/build/tmp/work/cortexa15hf-neon-vfpv4-oe-linux-gnueabi/ffmpeg/4.4.1-r0/recipe-sysroot -ffunction-sections -fdata-sections -fno-aggressive-loop-optimizations' --extra-ldflags='-Wl,-O1 -Wl,--hash-style=gnu -Wl,--as-needed,--gc-sections -Wl,--print-gc-sections,-lrt' --libdir=/usr/lib --shlibdir=/usr/lib --datadir=/usr/share/ffmpeg --cpu=cortex-a15 --pkg-config=pkg-config --enable-alsa --disable-altivec --enable-avcodec --enable-avdevice --enable-avfilter --enable-avformat --enable-avresample --enable-bzlib --disable-libfdk-aac --disable-gnutls --enable-gpl --disable-libgsm --disable-indev=jack --enable-libass --enable-libbluray --enable-protocol=bluray --enable-libfreetype --enable-librtmp --enable-libv4l2 --enable-libvorbis --enable-lzma --disable-libmfx --disable-mipsdsp --disable-mipsdspr2 --enable-libmp3lame --enable-libopenjpeg --enable-openssl --enable-pic --enable-postproc --enable-pthreads --disable-sdl2 --enable-shared --disable-libspeex --disable-libsrt --disable-stripping --enable-swresample --enable-swscale --enable-libtheora --disable-vaapi --disable-vdpau --enable-libvpx --enable-libx264 --enable-libx265 --disable-libxcb --disable-outdev=xv --enable-zlib
Used command:https://media.axprod.net/TestVectors/v7-MultiDRM-MultiKey/Manifest_AudioOnly_ClearKey.mpd: Invalid data found when processing input
I want to make a bouquet (channellist like this):ffmpeg -decryption_key 6df9cb035e776208f1017d42fa7870bb -i "https://media.axprod.net/TestVectors/v7-MultiDRM-MultiKey/Manifest_AudioOnly_ClearKey.mpd" -codec copy decrypted_media.mp4
So we can watch it on the fly#SERVICE 5001:0:0:0:0:0:0:0:0:0:http%3a//media.axprod.net/TestVectors/v7-MultiDRM-MultiKey/Manifest_AudioOnly_ClearKey.mpd?#decryption_key=6d f9cb035e776208f1017d42fa7870bb
Thx
Results 1 to 19 of 19
I'd like to also know if it's possible to play or add mpd+keys into enigma2 and put a live tv in the boutique section
Enigma2 is used in satellite dish receivers.
Do you have a satellite setup or not?
Can you watch the TV channels or not?
What is the name of the satellite? -
Yes, I have a satellite setup.
Yes I can watch channels
Astra 19.2
You don't probably know yet, but m+ has removed more than 20 HD channels, including all the big ones like CC, Fox, Hollywood, Neox, Disney channel, Nickelodeon, and many many more....... Now all those channels are only in SD. The satellite as we knew it in Spain is dying fast. Hope this answered your questions. -
Yes you have answered my questions. Thanks.
In my location I can't receive the Spanish channels on 19.2E only the 1M (Europe Wideband) which are just a fraction.
That's really bad degrading the quality to SD.
I am still not sure what are you trying to do.
Are you trying to add the channels (in better quality presumably) streamed from the internet to the satellite receiver bouquet? -
Strange place to be asking questions related to enigma. Have you thought of looking here? https://www.sat-universe.com/index.php?forums/iptv.521/
Noob Starter Pack. Just download every Widevine mpd! Not kidding!.
https://files.videohelp.com/u/301890/hellyes6.zip -
1. Flash your receiver with the latest openBh 5.3 - https://images.openbh.net/
2. Install E-Channelizer on your pc and connect to receiver.
3. Using E-Channelizer send userbouquet.skyuk.tv to your receiver
A example of userbouquet, just edit with working mpds/keys:
#NAME Sky UK (TV)
#SERVICE 4097:0:00:0000:0:0:000000:0:0:0:http%3a//linear017-gb-dash1-prd-ll.cdn.skycdp.com/016a/Content/DASH_003_hd/Live/channel(skycinemaaction)/manifest_hd.mpd&0=6&1=0&5=d65c31745a314617b54857f4 5619935d:Sky Cinema Action HD
#DESCRIPTION Sky Cinema Action HD
#SERVICE 4097:0:00:0000:0:0:000000:0:0:0:http%3a//linear017-gb-dash1-prd-ak.cdn.skycdp.com/016a/Content/DASH_003_hd/Live/channel(skycinemaanimation)/manifest_hd.mpd&0=6&1=0&5=029e6eace13aa56799b7e58d 9666a18e:Sky Cinema Animation HD
#DESCRIPTION Sky Cinema Animation HD
#SERVICE 4097:0:00:0000:0:0:000000:0:0:0:http%3a//linear016-ie-dash1-prd-ak.cdn.skycdp.com/016a/Content/DASH_003_hd/Live/channel(skycinemacomedy)/manifest_hd.mpd&0=6&1=0&5=f728d8c0626f366b14a07930 88cefd3d:Sky Cinema Comedy HD
#DESCRIPTION Sky Cinema Comedy HD
#SERVICE 4097:0:00:0000:0:0:000000:0:0:0:http%3a//linear016-gb-dash1-prd-ak.cdn.skycdp.com/016a/Content/DASH_003_hd/Live/channel(skycinemafamily)/manifest_hd.mpd&0=5&1=0&5=518ccde3de11f68c3cc4db87 7b861a3d:Sky Cinema Family HD
#DESCRIPTION Sky Cinema Family HD
#SERVICE 4097:0:00:0000:0:0:000000:0:0:0:http%3a//linear016-gb-dash1-prd-ak.cdn.skycdp.com/016a/Content/DASH_003_hd/Live/channel(skycinemahits)/manifest_hd.mpd&0=6&1=0&5=fb15e90bbe155cee9652fae2 56e9eb22:Sky Cinema Hits HD
#DESCRIPTION Sky Cinema Hits HD
#SERVICE 4097:0:00:0000:0:0:000000:0:0:0:http%3a//linear016-gb-dash1-prd-ak.cdn.skycdp.com/016a/Content/DASH_003_hd/Live/channel(skycinemapremier)/manifest_hd.mpd&0=6&1=0&5=92a7645f3856824bb5386d3a cbd7a23b:Sky Cinema Premiere HD
#DESCRIPTION Sky Cinema Premiere HD
#SERVICE 4097:0:00:0000:0:0:000000:0:0:0:http%3a//linear016-gb-dash1-prd-ak.cdn.skycdp.com/016a/Content/DASH_003_hd/Live/channel(skycinemascifi)/manifest_hd.mpd&0=6&1=0&5=bbc9feaf5c39c7e3d606db13 28886190:Sky Cinema Sci-Fi Horror HD
#DESCRIPTION Sky Cinema Sci-Fi Horror HD
#SERVICE 4097:0:00:0000:0:0:000000:0:0:0:http%3a//linear016-gb-dash1-prd-ak.cdn.skycdp.com/016a/Content/DASH_003_hd/Live/channel(skycinemaselect)/manifest_hd.mpd&0=6&1=0&5=8867bd9163b721ed18071130 ff48dfea:Sky Cinema Select HD
#DESCRIPTION Sky Cinema Select HD
#SERVICE 4097:0:00:0000:0:0:000000:0:0:0:http%3a//linear016-ie-dash1-prd-ak.cdn.skycdp.com/016a/Content/DASH_003_hd/Live/channel(skycinemathriller)/manifest_hd.mpd&0=6&1=0&5=9cda1c214af546ca1e2d8a82 564495b7:Sky Cinema Thriller HD
#DESCRIPTION Sky Cinema Thriller HD
#SERVICE 4097:0:00:0000:0:0:000000:0:0:0:http%3a//linear033-gb-dash1-prd-ak.cdn.skycdp.com/016a/Content/DASH_003_hd/Live/channel(sportsnews50)/manifest_hd.mpd&0=6&1=0&5=2c65f726b70269fa1af0dc36 18aab2a3:Sky Sports News HD
#DESCRIPTION Sky Sports News HD
#SERVICE 4097:0:00:0000:0:0:000000:0:0:0:http%3a//linear019-gb-hls3-prd-ak.cdn.skycdp.com/016a/Content/HLS_004_hd/Live/channel(skynews)/index_hd.m3u8:Sky News HD
#DESCRIPTION Sky Sports HD
#SERVICE 4097:0:00:0000:0:0:000000:0:0:0:http%3a//linear019-gb-hls1-prd-ak.cdn.skycdp.com/016a/Content/HLS_001_hd/Live/channel(skynews)/index_hd.m3u8:Sky News SD
#DESCRIPTION Sky Sports SD -
what format use?
#NAME Sky UK (TV)
#SERVICE 4097:0:00:0000:0:0:000000:0:0:0:http%3a//linear017-gb-dash1-prd-ll.cdn.skycdp.com/016a/Content/DASH_003_hd/Live/channel(skycinemaaction)/manifest_hd.mpd&0=6&1=0&5=d65c31745a314617b54857f4 5619935d:Sky Cinema Action HD -
Ok, I think I got it. 0=6&1=0&5=Here goes the Key.But what happens when an mpd has several Kid:key blocks? That is, KID1:KEY1,KID2:KEY2,KID3:KEY3...? Thank you
Oh! I forgot, does it work on OpenAtv? I can't install OpenBHLast edited by musicafm; 10th Oct 2024 at 02:26.
Hello, does anyone know why I can't open DAZN on Enigma 2, while it works on OTT Navigator? I'm using the following configuration:
Code:#SERVICE 5002:0:0:0:0:0:0:0:0:0:http%3a//dcf-fs-live-dazn-cdn.dazn.com/dash/dazn-linear-024/master.mpd&0=6&1=0&5=xxxxxxxxxxxxxxxxxxxxxxxxxxxxx :Zona Dazn #DESCRIPTION Zona Dazn
I've same problem.... last change on this stream was the user-agent string, but it's impossible to set and I'm not sure that it solves the problem
How to download mpd stream (DRM protected)?
By ddim in forum Video Streaming DownloadingReplies: 320Last Post: 23rd Jun 2024, 18:01 -
How to download a protected Brightcove stream
By kairaira in forum Video Streaming DownloadingReplies: 42Last Post: 24th Feb 2023, 15:50 -
Help downloading HLS protected stream
By AliasZA in forum Video Streaming DownloadingReplies: 2Last Post: 27th Apr 2021, 15:22 -
HLS Protected Stream Downloading Help
By Yamiraan in forum Video Streaming DownloadingReplies: 6Last Post: 30th Mar 2021, 15:57 -
By bodasaud in forum Video Streaming DownloadingReplies: 5Last Post: 3rd Feb 2021, 07:41
