I have released v_0.1.3 just now. I've added the ability to optionally choose Resolution and Bitrate as suggested above by @sipho.
Note: the bitrate best/worst option only functions for 1080 or 720 videos. I didn't see the point of extending that down to the lower resolution stuff (and in most cases they don't have variances anyway).
[Attachment 75174 - Click to enlarge]
The updated version can be grabbed at Github as usual:
Results 31 to 47 of 47
Thank you. The only snag is that it now dumps all the downloads in the root of the specified folder and not within their respective show folders. Small issue though.
Had quite a revamp over the last few days. Initially I designed this app just to kick off the command window and let Freevine do its thing. I've now decided to bring the command prompt into the app itself. Just looks a bit neater from a UI perspective.
Note: the step3 text box is a proper Command Prompt, so you can type whatever you like in there, as well as choosing all the preset radio button options.
I do have an issue with BBC streams only - with Freevine 1.0.5 onwards - where you have chosen to save a downloads folder. All other services use the saved folder just fine. Can't figure out what's going on with the BBC. Stabby has not been able to replicate the issue in Linux, so might be something odd with Windows. I'd be interested to see if anyone else can replicate this.
v0.1.4 is at GitHub
The updates being:
1. modified UI to separate service countries
2. modiifed UI to separate Download and Search & Information functions
3. added internal Command Prompt function within the UI, in lieu of passing to external Windows Command console
[Attachment 75257 - Click to enlarge]
Will likely keep the updates fairly minor for a while now and will just add new services as needed, if @stabbedbybrick adds any new ones to his Freevine script. -
Merry Xmas everyone. I have an update since @stabbedbybrick has released freevine v1.1.0
https://github.com/billybanana80/FreevineGUI/releases/tag/FreevineGUI-v0.1.6
FreevineGUI v0.1.6 changes
1. switched back to utilising external Windows Terminal command prompt. Easier to support and maintain application with.
2. added option to set Service Profile (only required for All4 currently)
3. added option to set All4 client "android" or "web"
4. updated commands (get, search, profile) in line with freevine v1.1.0
[Attachment 75740 - Click to enlarge]
[Attachment 75741 - Click to enlarge]
Note: this version only works with freevine v1.1.0 + given the command changes by stabbedbybrick.Last edited by billybanana; 25th Dec 2023 at 03:57.
Just want to say a heartfelt THANK YOU for doing this. Much needed by many of us who are less technically inclined
My pleasure. It's always nice to make things a little easier for those of us who want it to be so.
So I've been on a bit of a roll today. Have now updated to v0.1.7.
What's new:
1. added a Favorites function to enable you to store a list of followed series. Saves looking up the series URL each time you wish to download a new episode. When you highlight a row and click Copy it will take the URL and put it in the main command window ready to perform your actions. I find that pretty useful, hope you guys do to.
[Attachment 75774 - Click to enlarge]
[Attachment 75775 - Click to enlarge]
https://github.com/billybanana80/FreevineGUI/releases/tag/FreevineGUI_v0.1.7 -
I've made some more updates and have release v0.1.8 that takes advantage of Stabby's new "file" command.
1. added a Queue function to allow you to add multiple tasks to a queue and kick off processing when you are ready. The functions looks for the file queue.txt in the root of your Freevine directory. If not found it will create the file the first time. The queue contents will be retained in the application - and visible in the Queue window - at all times until you press Clear to remove the contents.
[Attachment 76008 - Click to enlarge]
https://github.com/billybanana80/FreevineGUI/releases/tag/FreevineGUI_v0.1.8 -
Have added some more features as per the Freevine code by stabbedbybrick and now that the app is pretty stable, have updated to full version 1.0.0.
https://github.com/billybanana80/FreevineGUI/releases/tag/FreevineGUI_v1.0.0
What's New ?
- added Import & Export function for Favorites for those that want to maintain the list on more than one pc
- added optional Audio Stream selection
- added no cache option
- added append ID to video file name option
- added force numbering option
- added sleep delay (number of seconds) between downloads
[Attachment 76292 - Click to enlarge]Last edited by billybanana; 19th Jan 2024 at 01:42. Reason: added link to release
Ok so I've gone a bit silly with updates again, but that should be it for a while now unless stabby adds any more brilliant functionality to freevine
FreevineGUI v1.1.0 changes
- added support for TVNZ
- added proxy configuration in Options (set Hola, Windscribe or Custom proxy). Proxy server locations listed in the Country Name dropdown will populate according to your set proxy option.
- added set Windscribe proxy credentials
- added Save File Name command
- added number of Threads option
- added additional N-m3u8Dl-RE command option
- added No Mux, No Mux Subtitles and Shaka Packager options
- Redesigned UI to move optional items under the 3 main program functions (service, action, process)
- added Test CDM function to Options menu
[Attachment 76379 - Click to enlarge]
[Attachment 76380 - Click to enlarge]
Direct link to file here: https://github.com/billybanana80/FreevineGUI/releases/download/FreevineGUI_v1.1.0/free...GUI_v1.1.0.zip -
I've made a few changes since my last post here primarily as updates with the freevine code from stabbedbybrick.
1. added support for RTE
2. added support for CBS
3. added Hola proxy server for Ireland
If you're using Windows and don't like having to type all your commands every time, then this may be for you.
New version v1.1.2 is available here -
Could someone please tell me what I am doing wrong? When I try to download https://www.crackle.com/watch/4f64428e-3db5-4ba2-8b57-c0d9a98db2bd/hansel-vs.-gretel from Crackle, I get these errors.
[Attachment 78690 - Click to enlarge]
[Attachment 78689 - Click to enlarge] -
freevine.py get -m https://www.crackle.com/details/3b498607-9dc3-4dd1-8af9-a5c2cc2b760b/hansel-vs.-gretel
I was able to replicate the same one time but then the next few times it passed the correct "movie" parameter to the command using the same options. Weird.
[Attachment 78697 - Click to enlarge]
Not something I would fix now anyway given I've archived the repo with Stabby no longer maintaining Freevine.
Freevine - A downloader for free streaming services (discontinued)
By stabbedbybrick in forum Video Streaming DownloadingReplies: 1612Last Post: 20th Aug 2025, 09:15 -
Ffmpeg add images to MP4 video, one in front, one in end
By zydjohn in forum Newbie / General discussionsReplies: 1Last Post: 23rd Dec 2021, 02:45 -
Windows 7 Portable Hard Drives
By Tom Saurus in forum ComputerReplies: 17Last Post: 21st Aug 2021, 14:23 -
PORTABLE Minimal Git for Windows (version 2.22.0.1)
By El Heggunte in forum ComputerReplies: 0Last Post: 22nd Jul 2019, 19:24 -
seeking commandline front-end for using NVEnc
By hydra3333 in forum Video ConversionReplies: 28Last Post: 6th Mar 2019, 14:13
