Hi,
I have "Problems with the toolbar while writing messages" Like italic, upload image, code, link, etc.
When i click nothing appears.
What may have happened?
Results 1 to 9 of 9
Interesting, because I have, very occasionally, hadn't the same thing happen to me. I've never been able to work out why, but it fixes itself when I next visit.When i click nothing appears.
I'm using Chrome.
Also interesting! I got a message from Java saying I "hadn't used it for 6 months, do you want to uninstall", which I have done. This site is working normally for me, so I suspect Java is not required here.Disabled javascript? -
Java script that runs in most webpages is not the same as Java SE downloaded from Oracle which gives a runtime
programming environment for the whole PC, and the browser - if you let java SE install the extension/plugin
I have an old version of java installed in one of my old XP boxes, for the sole reason of running a program
that uses java - for example,RipBot264 -
Yep. Java is something else.
All browsers has javascript on by default. But you can disable it to for example block most ads. -
On "Quick replay" , wich is not complete, work some time.
When i "Go Advance" not work. Ie:insert code, bold, upload image, etc. Work only fonts, sizes, colors and smile.
I have disabled all plugins(extensions) but don't work.
I use Edge
PS.The javascript is enable -
I think I found the problem. I loaded all external javascripts at the same time(asynchronous). But they should be loaded in correct order.
It works in Edge here now.Last edited by Baldrick; 13th Nov 2023 at 07:20.
Often error messages do not mean what they say
By El Heggunte in forum TestReplies: 14Last Post: 2nd Jan 2025, 11:39 -
Weird VideoHelp messages
By rrats in forum Off topicReplies: 1Last Post: 27th Jul 2022, 14:02 -
Womble MPEG Video Wizard Toolbar Missing
By John Oss in forum ComputerReplies: 3Last Post: 26th Nov 2020, 12:26 -
MPC HC toolbar in Dark Theme
By noob00225 in forum Software PlayingReplies: 1Last Post: 16th May 2020, 20:50 -
Potplayer - how to remove top toolbar?
By jeb2020 in forum Software PlayingReplies: 0Last Post: 23rd Apr 2020, 21:11
