I have a few-minute-long video recorded with a static camera. Noisy, but I was happy with Neat Video's denoising.
However, I have seen better results on such videos (where 99% of the image is still) using TemporalDegrain2 (I can't find the thread at the moment).
So I used:
And I get a "stunning" 0.01fps for 4k footage -- that's several hours for 200 frames!Code:ffms2("joined.mp4") assumefps(30) convertbits(10) converttoyuv444(matrix="PC.709") levels(10,1,900,0,1020,coring=false) TemporalDegrain2(degrainTR=4,grainLevel=3,postFFT=3,postSigma=1)For comparison, Neat Video = 0.30fps.
Is there any way to speed this up? Am I doing something wrong?
Results 1 to 14 of 14
You can try adding prefetch(x) , where x is some number >1 for multithreading. But it will still be slow.
Neat video should be much faster with a decent GPU
Is 99% of the image still in the same section of the frame with no change ? If so, crop to the region of interest and process that with the denoiser, composite with a still frame -
a. depending on your setup LWLibavVideoSoure with enabled hardware decoding might speed up the decoding of the source
b. using mulithreading (see: http://avisynth.nl/index.php/SetFilterMTMode; set SetFilterMTMode at the start and Prefetch at the end of the script)users currently on my ignore list: deadrats, Stears555, marcorocchini -
Hey, its a 5x improvement!! That's actually pretty darn good.
1. Have you tried it with the default settings?
2. Have you read all the comments in the AVSI file? For instance, it says, "currently just postFFT=0, 1 and 4 are supported for high bit depths." You are using postFFT=3. Not sure what that might do. I only skimmed the AVSI just now, and did verify that the default for DCT in MVTools2 (the one plugin I know very well) is 0. If it gets set to anything other than that, speed can go down to about 10% of what it is at DCT=0.
3. Try different Prefetch numbers. Try setting it to about 1/3 the number of cores you have. I often get negative speed results when Prefetch > 1/2 number of cores.
4. What resolution are you feeding it? Try adding a resize to half resolution in each direction as the first line in the script, and then run the script for a minute. See what sort of speed you get. I'm not suggesting that you permanently want to degrade your video, but am merely trying to help pinpoint what factors might affect speed. I have found MVTools2 to be very unforgiving when you feed it really high resolution video.
What version of MVTool2 are you using? The older the version, the more likely you are to have speed issues.
[edit]I suggest searching the long TemporalDegrain2 thread at Doom9.org. Someone there posted a much faster version called "Temporaldegrain2_fast". Look for that and see if it is faster, but without compromising the quality.
https://forum.doom9.org/showthread.php?p=1982594#post1982594Last edited by johnmeyer; 22nd Nov 2023 at 18:40. Reason: forgot to add "DCT" in one sentence
What computer are you using as in specs?
It is complex script with several different denoisers.
At least vsTTempSmooth got update in performance using AVX2 in latest builds in Asd-g github in 202x years - recommended to use lastest version.
Also MAnalyse using dct > 0 (from fftw library) may run significantly slower in comparison with spatial modes (with dct=0).
If you use Win10 or later and GPU with MPEG-encoder hardware chip with DirectX12 Motion Estimation capable driver you can try mvtools of post-2.7.45 builds (typically blocksize of 8x8 only run stable). https://forum.doom9.org/showthread.php?t=183517 . See examples of hardware accelerated scripts in that thread with optSearchOption=5 or 6. It should support 4K resolution.
And for possibly much better performance with mvtools only denoise much simple scripts may be tested like EZdenoise. -
I think even a Cray supercomputer would meet its match running Temporaldegrain...
Fair warning, I am going to say a bunch of "stupid" things.
Have you read the guide related to this script:
http://avisynth.nl/index.php/TemporalDegrain2
Under Suggested settings for removing the grain, sorted by increasing source grain it lists the following settings for the most grainy sources:
degrainTR=2,grainLevel=3,postFFT=1,postSigma=value between 0 and 2
Now compare to your settings:
I would also try to use FFT3D directly and eliminate everything else.
http://avisynth.nl/index.php/FFT3DFilter
I have always felt that people filter their stuff way too much. To me filters are like spices for food, a bit of salt, some pepper, maybe oregano or something a pinch of something else, and that's it.
But many people seem to want to add everything in the spice rack and it becomes overpowering.
Keep it as simple as you can.
The other thing is you mentioned that when you change the settings your ram usage goes way up. This is a sign that if you intend to do this type of work you need more ram. -
After a few attempts with the settings, I stayed with Neat Video. I achieved better denoising using TD2, but at the cost of losing details, especially with moving parts (and I only used degrainTR, the rest at 0).
I need help with the TemporalDegrain2 filter script error
By Marcio.ciconne in forum RestorationReplies: 4Last Post: 21st Sep 2023, 17:05 -
Degrain HDR - TemporalDegrain2 not working?
By Cuissedemouche in forum Video ConversionReplies: 8Last Post: 10th Dec 2021, 11:43 -
error with temporaldegrain2
By Betelman in forum RestorationReplies: 47Last Post: 6th Feb 2020, 05:19 -
USB 3.0 transfers are slow
By kyrcy in forum ComputerReplies: 27Last Post: 16th Dec 2019, 20:35 -
Help about slow encode speed
By Mohamet in forum Video ConversionReplies: 5Last Post: 25th Feb 2019, 05:42
