Hi, I've been having a problem with Subtitle Edit for a few days.
Suddenly the audio of any video no longer works in the software, even if the PC audio works perfectly.
I have not changed any settings either in the software or on the PC and I have not made any updates.
I also tried uninstalling and reinstalling Subtitle Edit but the problem persists.
How can I solve the problem? Thank you very much for helping!
Try StreamFab Downloader and download from Netflix, Amazon, Youtube! Or Try DVDFab and copy Blu-rays!
Results 1 to 14 of 14
Look in options/settings/video player
What does it have for video engine?
If it's directshow, verify it's working by opening and playing the video(s) in Graphedit.
https://www.videohelp.com/software/GraphEdit
If it's not working properly (ie. no sound) reinstall your dshow filters (eg. LAV filters) -
Thanks for your help. In settings Mpv is default. I tried switching to DirectShow and to VLC media player, but the audio still doesn't work.
Excuse me, can you explain to me in simple words what I should do with Graphedit? I'm not familiar with computers. I installed GraphEdit 10 but it won't read video files. -
No, the audio is active and all the software options are as before the breakdown. As I was saying, I also tried uninstalling and reinstalling it, but the problem persists. I thought there was a sudden incompatibility with the PC audio but I understand little about PCs and I don't know how to intervene.
Try to check your system health.
Use Dism-GUI
https://files.videohelp.com/u/292773/Dism-gui.zip
Use the correct version for your OS, 32bit x86 or 64bit -x64.
Start it, click SFC scan, wait until the scan is finished.
If errors are found, reboot and repeat the scan.
If no more errors are found, click (Online) Scan.
If no errors are found here, everything is ok.
If not, click (Online) Restore, at Restore source uncheck the box at
limit access, then click online.
An attempt is now made to repair the component store.
If it is successful, you will be notified.
Then reboot the computer.Last edited by ProWo; 12th Nov 2023 at 13:59.
If you start Dism-GUI, should pop up an UAC request window. Click yes on it.
Read this first
https://softwarekeep.com/help-center/how-to-fix-windows-resource-protection-could-not-...repair-service -
You should check your system anyway.
it is not normal that the error message
"Windows Resource Protection: Recovery Service could not be started." appears.
This means that you either have a defective file system or that the "TrustedInstaller (Windows Modules Installer) service" was/is unable to start.
Both must be fixed in any case.
Subtitle edit - How to put 'A with a dash on top' in subtitle edit?
By SSEN in forum SubtitleReplies: 5Last Post: 21st Sep 2023, 20:57 -
Subtitle Edit 3.6.10: breaking line problem
By Nounours18200 in forum SubtitleReplies: 5Last Post: 11th Jan 2023, 15:24 -
Subtitle Edit VOB problem
By Lostdog in forum SubtitleReplies: 13Last Post: 28th Sep 2021, 20:11 -
waveform problem in Subtitle Edit 3.4.6
By whitelighter27 in forum SubtitleReplies: 2Last Post: 15th Mar 2019, 06:14 -
Subtitle edit audio profile - audio sync error.
By hibbs in forum SubtitleReplies: 9Last Post: 11th Dec 2018, 20:44
