  1. Member GlitchBob's Avatar
    Feb 2006
    So for some really absurd reason, Sony managed to release this series on DVD in PAL format (25fps, 720x576) but it's all interlaced. The series was not made that way, so it's quite curious.
    In any event, I cannot figure out how to get it properly deinterlaced. My best attempt was with nnedi3, which retains the 25fps, but the deinterlaced frames are a tad jagged and have some "shimmering". Any assistance would be greatly appreciated.
    Mar 2008
    Sometimes the fields in PAL movies are offset this way,
    try
    mpeg2source(....)
    assumetff()
    tfm()
  3. Yes, it's mostly progressive video which is encoded as interlaced with occasional field shifts. It has probably been done like this for framerate conversion to 25fps.
    TFM(mode=1,pp=6) will match the fields and return the progressive frames, and deinterlace only the remaining orphaned fields for which no match is found.
    http://avisynth.nl/index.php/TIVTC
    Also try
    AssumeTFF()
    QTGMC(FPSDivisor=2)
    Edit:
    You may want to compare and optimize the 2 variants like
    LWLibavVideoSource("WhySonyWhy.m2v")
    assumeTFF()
    left=QTGMC(FPSDivisor=2)
    right=TFM(mode=1,pp=6,display=true)
    stackhorizontal(left,right)
    Left is QTGMC, right is TFM:
    Mar 2008
    "TFM(mode=1,pp=6)"
    Thanks for this refinement.
  5. Originally Posted by davexnet View Post
    "TFM(mode=1,pp=6)"
    It's actually the default AFAIK, so it's the same as TFM(). I just added it so the OP may want to try out other (better) settings.
  6. Here another proposal using BWDIF with nnedi3:
    BWDIF(field=1,edeint=nnedi3())
