How do I use selectevery(48), selectevery(72), and imagewriter() to losslessly extract frames in AVIsynth?
Here's a model you can use:
Download Lsmash/LWLibsource from here:Code:LwLibAvVideoSource("c:\path\source.mp4") # << this points to your source file selectevery(72) # << extract every 72nd frame ConvertToRGB24() imagewriter("i:\media\images\",type="png")[ # << place PNG files in this folder
https://github.com/HomeOfAviSynthPlusEvolution/L-SMASH-Works/releases/download/1147.0....r1147.0.0.0.7z
Extract the files and put the 32 bit and 64 bit Lsmashsource.dll into the respective Avisynth Plus plugin directories
Open Vdub2 and drag the .avs script into the window. If the script is good the video will appear.
Select file/run video analysis pass to take a pass through the video and create the png files
Cut .TS files losslessly on I-Frames while preserving all other streams
By phelissimo_ in forum DVB / IPTVReplies: 8Last Post: 21st May 2025, 01:42 -
Extract the Best Frames
By Jay123210599 in forum Newbie / General discussionsReplies: 23Last Post: 17th Nov 2023, 01:55 -
Losslessly Extract Keyframes
By Jay123210599 in forum Newbie / General discussionsReplies: 28Last Post: 9th Nov 2023, 22:14 -
Avisynth+ and grabbing x frames every y frames? I'd like to sample a clip
By Msuix in forum EditingReplies: 2Last Post: 11th May 2021, 15:41 -
Losslessly exporting frames from a .VOB - am I doing it right?
By bentley in forum Video ConversionReplies: 23Last Post: 25th Mar 2020, 10:35
