Hello,
I am trying to download from hotmart.
Up to about 20 days ago, HLS Downloader was working wonders and doing a great job:Chrome extension page for HLS downloader
Then something changed in hotmart and now their m3u8 playlist look like they give you always access denied. No extension or program is really working to download their video directly. I tried a lot of them including the ultra celebrated Video DownloadHelper, ffmpeg. No luck.
The usual video link looks like:
https://player.hotmart.com/embed/VIDEO_ID?signature=VIDEO_SIGNATURE
but since people will need public link to help me, here's 3 of them that have the same problem:
https://player.hotmart.com/embed/Yq2jK1o5qa
https://player.hotmart.com/embed/nRvJ0kkYRQ
https://player.hotmart.com/embed/Pq9rbvnDLO
I tried from chrome dev tools too to figure out what is going on in the js code but coulnd't come up with anything.
The only way I found to do it is use
CocoCut Chrome Extension
which has a convenient recording stream function.
The problem though, is that it requires me to watch the whole video or skim through it for the whole length because it has to record every chunk of it.
Really annoying.
Does anyone know how to beat this one?
Results 1 to 18 of 18
I tried only the third video: it is not protected at all. yt-dlp will download it if you add the referrer as header field: "yt-dlp --add-headers 'Referer:https://player.hotmart.com/' 'https://vod-akm.play.hotmart.com/video/Pq9rbvnDLO/hls/master-t-1654025595001.m3u8?...'" - I guess the others aren't protected as well.
You can find the full url of the m3u8 link with your browsers dev tools, but your browser extension should find it as well. -
Thank you,
What about this:
https://www.calimove.com/courses/1467532/lectures/33641283
I can't do it with the referral thing -
Thank you I tried with some of this:
But adding the header didn't work.
Did I miss something?
DO you mange to get them? -
Code:hlsdl -b -c -u "Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/119.0.0.0 Safari/537.36" -h "Referer:https://player.hotmart.com/" -o "master-t-1658736450001.ts" "https://vod-akm.play.hotmart.com/video/5Z3yd138qa/hls/master-t-1658736450001.m3u8?hdnts=st%3D1699723786%7Eexp%3D1699724286%7Ehmac%3D9c3f6e93809fd3fe71ad342730e143b70bc50c762f92ed496870c9e07abc1105&app=aa2d356b-e2f0-45e8-9725-e0efc7b5d29c"
I'm in a DRM protection situation. I got the .MPD video link but yt-dlp doesn't work because of protection.
Code:[generic] Extracting URL: https://vod-akm.play.hotmart.com/video/7Lypzy9kqA/drm/dash/stream-t-1698692362001.mpd?hdnts=st%3D...d0-9c59-cfe00909f280 [generic] stream-t-1698692362001: Downloading webpage WARNING: [generic] Falling back on generic information extractor [generic] stream-t-1698692362001: Extracting information ERROR: [generic] stream-t-1698692362001: This video is DRM protected
Any suggestion? -
I believe that only I who have access to the Hotmart account credentials will get permission to access the video manifesto link. You would only be able to access it if I provided my credentials.
So I believe the most I can do is send the corresponding error messages. I am researching alternatives and willing to find a solution. -
Hey the videos that I'm actually able to successfully download thatnks to Obo precious suggestions, are actually a paid course behind a login.
What I did is:
1)install some extensions to catch m3u8 file
2 I tried are- FetchV
- M3U8 Finder and HLS Player
Why 2? Because Yesterday I fetched a lot of playlists to download with FetchV, and today it misteriously stopped working, so I had to find another one.
Now the extension will tell you the m3u8 url, which in my login walled videos page looks like this (i replaced tokens with brackets):
2) Follow Obo advice and set command like this:https://vod-akm.play.hotmart.com/video/{VIDEO_ID}/hls/master-t-{PLAYLIST_ID}.m3u8?hdnts=st%SOME_TOKEN%7Eexp%{EPIR ATION}%7Ehmac%{SOME_TOKEN%}
And to my disbelief it's actually working.yt-dlp -o "VIDEO_NAME.mp4" --add-headers Referer:https://player.hotmart.com/ https://vod-akm.play.hotmart.com/video/{VIDEO_ID}/hls/master-t-{PLAYLIST_ID}.m3u8?hdnts=st%SOME_TOKEN%7Eexp%{EPIR ATION}%7Ehmac%{SOME_TOKEN%}
I tried countless tricks and it was that easy, at least for me and I'm downloading from a page locked behind a login from teachable courses.
What else can I say?
Thanks Obo, you saved me this time! - FetchV
So, the video manifest does not refer to a .m3u8 playlist, when it comes to that I have no problems. Now the problem is when the video manifest refers to a .mpd
See I use the following command and in yl-dlp to download playlist .m3u8
yt-dlp --add-header "Referer: https://player.hotmart.com/" --format best[height=360] "URL"
the problem is that the .mpd URL has DRM protection and yl-dlp cannot handle it:
Ex of a DRM protected URL:
Code:yt-dlp --add-header "Referer: https://player.hotmart.com/" --format best[height=360] "https://vod-akm.play.hotmart.com/video/7Lypzy9kqA/ drm/dash/stream-t-1698692362001.mpd?hdnts=st%3D1699765373%7Eexp%3D1699765873%7Ehmac%3Dcaf91000fb5ef6b9500103e2893d0337d75771780e155d8ee8abe39d2 5fe4d0f&app=f57b1bb2-30e3-4fd0-9c59-cfe00909f280"
Note that unlike m3u8 which uses HLS, mpd uses Dash. -
Nope, the mpd url itself is not DRM protected (and that doesn't even make sense); it's missing some kind of authorization - you get a 403 - forbidden response.
What I'm trying to say is that I found that a video on the platform was via HLS/M3U8 and I was able to download it normally via Yt-dlp. While the other video was protected by DRM and the Dash/MDP process and in this case yt-dlp was unable to download the video reporting the message " ERROR: [generic] stream-t-1698692362001: This video is protected by DRM "
So the differentiation I made between both methods was based on my observation of these two cases used on the Hotmart platform. I'm not saying that this is the case in all cases.
I will even leave here the two examples of URL manifests with the two methods I mentioned:
2- I was unable to download via yt-Dlp:Code:1: I was able to download via Yt-dlp: yt-dlp --add-header "Referer: https://player.hotmart.com/" --format best[height=360] "https://vod-akm.play.hotmart.com/video/gL6aOAWmqG/ hls/master-t-1698690261001.m3u8?hdnts=st%3D1689813085%7Eexp%3D1699813585%7Ehmac%3Db1dfd4386e4389bfcdba0561111863b06e1164d1e4d51ccdad77e42 3211ab5bf&app=f57b1bb2-30e3-4fd0-9c59-cfe00909f280"
Code:yt-dlp --add-header "Referer: https://player.hotmart.com/" --format best[height=360] "https://vod-akm.play.hotmart.com/video/7Lypzy9kqA/ drm/dash/stream-t-1698692362001.mpd?hdnts=st%3D1699765373%7Eexp%3D1699765873%7Ehmac%3Dcaf91000fb5ef6b9600103e2893d0337d75771780e155d8ee8abe39d2 5fe4d0f&app=f57b1bb2-30e3-4fd0-9c59-cfe00909f280"
Hi Everyone:
The answers seem kind of cryptic vs the initial question, which was easy to understand and my issue and question as well.
Can someone briefly summarize the final correct code to use. I tried to deconstruct, but still didn't make sense in the end.
Here is the summary of the code given:
In a prior posts, an answer was given with the following:
If we can get an answer on what finally worked so I and future questioners can understand it will be appreciated.
What I don't understand is the headers part.
I found this documentation:
"--add-headers FIELD:VALUE
Specify a custom HTTP header and its value, separated by a colon ":". You can use this option multiple times:"
I just don't know if I am suppose to replace with actual headers or leave as a literal "--add-headers"
when I tried with a literal "--add-headers" I got the following error:
Unable to download webpage: HTTP Error 403: Forbidden (caused by <HTTPError 403: Forbidden>);
so, leaving out some of the code above to make it simpler:
yt-dlp --add-headers Referer:https://player.hotmart.com/ https://vod-akm.play.hotmart.com/video/{VIDEO_ID}/hls/master-t-{PLAYLIST_ID}.m3u8?hdnts=st%SOME_TOKEN%7Eexp%{EPIR ATION}%7Ehmac%{SOME_TOKEN%}
Thanks in advance! -
Just use The Stream Detector browser extension, it will let you copy the full yt-dlp command without a fuss. In my case:
Code:yt-dlp --no-part --restrict-filenames -N 4 --user-agent "Mozilla/5.0 (Windows NT 10.0; Win64; x64; rv:121.0) Gecko/20100101 Firefox/121.0" --cookies-from-browser firefox --referer "https://player.hotmart.com/" "https://vod-akm.play.hotmart.com/video/Yq2jK1o5qa/hls/master-t-1647616645001.m3u8?otherparameters..."
Thanks for that addon. It's a great help, but I was unfortunately not able to download the videos. I got a 403 error. I didn't pay for the course, so I was trying to download anyways. Interesting though that I wasn't even able to download the 3 free videos.
Anyways, other than maybe some --header that I could add to my command, which I don't know much how to use anyways, I think I probably cant download.
Thanks again for the firefox addon though! -
I have the same problem.
Referer change will not work.
Does anyone have a solution?
Need help downloading
By Angel_Cyclops in forum Video Streaming DownloadingReplies: 36Last Post: 19th Feb 2025, 07:00 -
Help for downloading
By talms in forum Video Streaming DownloadingReplies: 8Last Post: 27th Jan 2023, 07:04 -
Help downloading TS
By dzigelbaum in forum Video Streaming DownloadingReplies: 1Last Post: 22nd Dec 2022, 05:08 -
Help downloading this
By kienkzz in forum Video Streaming DownloadingReplies: 10Last Post: 18th Apr 2022, 13:06 -
Help downloading from iq.com
By dami3n in forum Video Streaming DownloadingReplies: 10Last Post: 3rd Apr 2022, 04:27
