    Jun 2020
    Hong Kong
    I used to use pywidevine to get the wv keys of mytv super, a hong kong streaming platform (with free sections), but it was not functioning when i try it today.
    Error message:
    [+] License Response: b'U3RhdHVzIDQwMDogODAyMDUgSW52YWxpZCBkZXZpY2UgSUQK '
    unable to parse license - check protobufs
    base64decode: Status 400: 80205 Invalid device ID
    I have check my cdm is still valid since I can get keys from other sites. I have also checked the contents of headers.py is the same as the headers of post request from the original app. What may possibly go wrong?
    Many thanks.
    Dec 2021
    england
    it need login
    Jun 2020
    Hong Kong
    Originally Posted by iamghost View Post
    it need login
    i can pm you with a free acc, can you help?
    I was using the headers information from android app because i only have android cdm.
    Jun 2020
    Hong Kong
    problem solved.
  5. May I ask how it was resolved? Thank you
