Pretty sure it is not possible to obtain Playready keys, just wondering is the following link encrypted with Widevine keys as well. Is there a way to confirm this?
EME logger shows several key systems including Widevine, anyway to force the Chrome browser to use Widevine?
https://www.britbox.com/us/show/8_Out_of_10_Cats_Does_Countdown_p07n5vbg
https://vod-dash-ntham-comm-live.akamaized.net/usp/auth/vod/piff_abr_full_hd_jit_cenc_...6d00832f34bb65
AAAAXHBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADwIARIQvJ tnvlW9SkWtTGd7Cp9mqxoIdXNwLWNlbmMiGHZKdG52bFc5U2tX dFRHZDdDcDltcXc9PSoAMgA=
Requires US proxy, can PM log in credentials if keys are possible.
Presumed it would be using Widevine as Britbox Uk does.
Cheers
Steve
Results 1 to 10 of 10
Hmm... PlayReady is not cracked open yet, but it doesn't mean it's impossible to get those PlayReady keys.
Chrome only supports Widevine afaik, you should use Microsoft Edge if you wanna stream PlayReady protected contents.
Of course, I would desperately learn the PlayReady way if possible. -
The key of your video found with Keysdb.net
Code:dde9f291111a47219aea40d7f77f378e:3da88313ec59bab6644d856a6351d83a
[Attachment 74786 - Click to enlarge]
Download and decrypt with N_m3u8DL-RE
Code:N_m3u8DL-RE --key dde9f291111a47219aea40d7f77f378e:3da88313ec59bab6644d856a6351d83a "https://vod-dash-ntham-comm-live.akamaized.net/usp/auth/vod/piff_abr_full_hd_jit_cenc_v2/9b1ffc-p07r3lyy/vf_p07r3lyy_295f159e-ab19-4bcb-9071-d1ce2686e7aa.ism/pc_hd_abr_v2_dash_master.mpd?__gda__=1699570551_365b5bebc7a3cd92fb6abed2c8e8a20b" -M format=mp4
[Attachment 74787 - Click to enlarge] -
On the video page using google chrome press ctrl+shift+i and switch to the network tab, then in filter enter "acquire" without quotes, then start playing the video, you'll see AcquireLicense under the Name column, click on it, then under the Headers tab you can get the Request URL:
Code:https://389887f2.drm-widevine-licensing.axprod.net/AcquireLicense
Thanks, cannot seem to find the headers required for the license server.
Please can you confirm how to do this?
Tried from the headers tab:
eyJ0eXAiOiJKV1QiLCJhbGciOiJIUzI1NiJ9.eyJ2ZXJzaW9uI joxLCJjb21fa2V5X2lkIjoiMGFkNmQwZjAtODBlNC00YWM4LTk xNTMtYWRiNzAwY2VmYjY1IiwiYmVnaW5fZGF0ZSI6IjIwMjMtM TEtMDlUMTk6NDg6MDcuMjkzOTQ1WiIsImV4cGlyYXRpb25fZGF 0ZSI6IjIwMjMtMTEtMDlUMjA6NDk6MDcuMjkzOTQ1WiIsIm1lc 3NhZ2UiOnsidHlwZSI6ImVudGl0bGVtZW50X21lc3NhZ2UiLCJ 2ZXJzaW9uIjoyLCJsaWNlbnNlIjp7InN0YXJ0X2RhdGV0aW1lI joiMjAxOS0xMS0xMlQwNTowMDowMFoiLCJleHBpcmF0aW9uX2R hdGV0aW1lIjoiMjAyMy0xMS0xMFQxOTo0OTowNy4yOTM5NDVaI iwiYWxsb3dfcGVyc2lzdGVuY2UiOmZhbHNlfSwiY29udGVudF9 rZXlzX3NvdXJjZSI6eyJpbmxpbmUiOlt7ImlkIjoiQkM5QjY3Q kU1NUJENEE0NUFENEM2NzdCMEE5RjY2QUIiLCJpdiI6IjExZkU 3VENTU1BBU3BaKzZjVlkyM0FcdTAwM2RcdTAwM2QiLCJlbmNye XB0ZWRfa2V5IjoicnZPSlcrd2Zaa1orY3FsSy9BZGRCd1x1MDA zZFx1MDAzZCIsImNvbnRlbnRfa2V5X3VzYWdlX3BvbGljeSI6I mJyaXRib3hfc3RyZWFtaW5nX3BvbGljeSJ9XX0sImNvbnRlbnR fa2V5X3VzYWdlX3BvbGljaWVzIjpbeyJuYW1lIjoiYnJpdGJve F9zdHJlYW1pbmdfcG9saWN5Iiwid2lkZXZpbmUiOnsiZGV2aWN lX3NlY3VyaXR5X2xldmVsIjoiU1dfU0VDVVJFX0RFQ09ERSIsI mhkY3AiOiIyLjAifSwicGxheXJlYWR5Ijp7Im1pbl9kZXZpY2V fc2VjdXJpdHlfbGV2ZWwiOjIwMDAsImFuYWxvZ192aWRlb19vc GwiOjMwMCwiY29tcHJlc3NlZF9kaWdpdGFsX2F1ZGlvX29wbCI 6MzAwLCJ1bmNvbXByZXNzZWRfZGlnaXRhbF9hdWRpb19vcGwiO jMwMCwiY29tcHJlc3NlZF9kaWdpdGFsX3ZpZGVvX29wbCI6MzA wLCJ1bmNvbXByZXNzZWRfZGlnaXRhbF92aWRlb19vcGwiOjMwM H19XX19.wfyTk0Lj5fr3Y_GwLipNymdsgGE1ve1k8SXKsZt-WB4
This failed to generate the keys.
Cheers -
thanks, tried with just:
Will not generate key, from cedrics post the header field is populated. I found this is eme logger Message Type: license-request, but still generates error in keysdb.net when I use this in headers:
CAESnCASVApSCjwIARIQvJtnvlW9SkWtTGd7Cp9mqxoIdXNwLW NlbmMiGHZKdG52bFc5U2tXdFRHZDdDcDltcXc9PSoAMgAQARoQ 9yIT1wLQRBpZv3Oqxq40tBgBIMm/t6oGMBY4usbS7AlCph8KCmF4aW5vbS5jb20SEGHlYSsxIFM0kE RvoAWtrXoa8BwJTfleD/Q/U2PeMMJ6tusaq4c/7zat9XVds44P175WhY5vUk9g7BTDC90gVv2dHZqWu8UuMeWS84 cJNnnrnA0/kQOzNn3RLlpubH5f22EZklWBYzbMlLx2AtW5G/QXW20T8dVpitJcC58Yc11xxKk7wM1I8a/ShBlEoLN1MEcewvMbzpiWBdrA+Ezq0H5fWQB03V5Q5MM1zYsjx 4y+aocSouuzkHugy7nD6Je/1KyvuEuacYEMaFZCAguV2xCv/ELFcCpEuq3dQD8AjlQXm1ull2Lj5NwVfWVZ9zKe+VRl622MrxM G9lNfNjCDjeQTJOE59o5+LgJb7I2K5/iCzMXRrCLLccsptC+Rr92ZdwuOc5RXCx59JGjXv3gHLgKgyF2j xb+hhIMGDAPAgQ9dtA3rBfBN+9YmlZegTjbFLQQDzcG1GgHyNy +8S061O3hTx5bU5dB/kJ1nrUNAfKUrZvIkChHvWwRIntlvK3nwlr8HMsGFv0wbB6IQg3 XsqjBbz01uWBxdhGtfsNp9WMoXn2px3m8gKBpjcZq80mXDrD63 M/qAPxTzaoevZhp8ZaBmnvZW2OgiMSCD7e7w/jTK28TcRxRKp1a6mcnPcYgUYUOF+vGq2hSw5Q1xqEJT0WJxQ+c IytzZw7HD1e1iKsIk4yAmOpNJ2TD/NYUqurmAP7SDi8I0O/A/Gk/1oczF0BZQ5I0TKpUdMP7xkepcbqqo/3e00th6tcsGTKT2O53TRalPL9mmSS0jGYSLt2nHmz78GLBa2f+ m3+G6Fr9UjYwpiE33xBn7howZ+r8Tq+ye8GYl2OIHB4fusiwww fg76lv2Museyvh/mmMWB+acp0f+RTLh/PxcA7xgbY2nlPxJh2dsacj+L9Xs/0eYb0kxg3IRpPoG59sAce+FQsZERG3QWVMSB6QpQkDBLL2NDFB IYMTg8bs1c3lmza9yL2xCIk6Lj5yYhAWbvLGzyuxF+jBGGOIpS sbnkNoys6VjePxWGIre6U7bi492aabmT+SoNM6eh9gq8Qsbb6a ScwH1DK7c09f8N+2uEbvARPNUYoOmmt6NMtnYCyiPEnQ72nq+W zvs6wMR8C/9/LlHXaRJWDooZrf82GcT2OyOi/5WfWULy45TAv8KXsYH8gAeJWHfnP4ZaFLlmIN4/VF9d2eY+UimZjlM7GZkU881T+avciQLrHnYulGZDdvRYbj/wKRf4z4UA7ZIfCLJkqINTcMDMVCWXUZnyjj2hfLeoanI3JiO8l ZcKdKloCtrmgie97UDE5qBTnZQfA99HebUKpdxkd557evRcuC9 uCJ2ayUeRDGgiePGXXdasptnFwdxbRDFKI1d35Bo6nyBYuZiT7 YIkVxPHvBgGiJhFridmr9DgQsgNUVtHv/izX8J/Q4Rv98thLf5YFHT2LLm6WExAYoKA3RXpK6t6v6QEfeQV0Sx6Ap r2ZJEBExYgZ/rEO44Lrj7Ect5YiFD2ItBvaFipqleRHY5wSvEeOxrbMB9oWwrF aNisxkXVJcWIhnT/8TPJ1XRs9hmIvh5JQ/6KGaIRS9rH+kjNTPUi16kW0JyABHw6e+esAx6c4ohPUTV5xnA6 pnN2XFWt5xqenNzt2Lnq34blIE6yI0s0Ba3wMh/RPaM6ijRTdLwWlbuC4fzIB3mns6XQmSSBebufOTVNGM35lil5k QG0trNNbjfVtPso5QaUoy8OacE/7V7R/5JGI/hsVBbU8i2jNKcG/y4L7fidyy/JuMWylDU94JBVMSPvu2v1FYyOmBtvuB63MJ0OdiILRqkPD6ZTp YyV6bG8hcQ6ngPR4fSN5KCLRrBmZ7lcVgUQXzHofX7JcFgwEnV OeHlxXbLr58fWTQL8xriyfEZj71aUtIL7gWY/Z0p2l8tBRwgOwXvjDFhF8VYnCapojETB69ip+oO/9L8PQU1LseZKD9rK1B0gz/WWZ+LBMNQ4DTHVLiKtC/6ePTXVCU9FPAE+l9sisrujbrfTiSR0ZtNWAOA39FsdfPuaQpdP QDJdCPtNZk6Fsg/ZwacTqgj3GuVjPF+eeKBFYHq54HSwi6dAdvI/qtqlXto9VT28Ydn2hwzl5XWsDhiXmrkRD/r981JlxnM3/HxvfmCGF7OAeHnW2GJk8awMUwzPPShntamEBKGkm/kNWpCCNxLMD1GX11Dgfd2e77XIo9tLBF1E04tPVoPLBz6e1gHX MOkTNBZ9AbB3UhIXdGqIHl2uw6UX6ZR2ElIE8hg9wYgMit144K NGwCaryQQFRXkhm/TRCje2OkxWxmmu/ex72tpZ8Tfd+qk2DT9dCQaf/Mnf17xJ6KSlxKN59vY2ZcGQpCgV7Ck2UEc6w91Z1sBBb6Wej0V QRXlN7j5ViRSmyc5qHuxiWtsyyLejAHkrJ+A8eZvDPEnhSlfUk fAcELovRqomdfodsHcqbXcT9byddFLjZAexuANwWsBJ0CwFGez SseHkFimn0pwfnPcNz9bxplaPrW7s3zFx88bWg25Hv+f0npamO FpLwl3jUCp48LMQwmok3PEiknBf0//0P1Fd2FS1L4iJq6nV6TsmkSaFVgRGW5jgqV1oSL5It1ejiIR0/N8rmb1/YgbRuJbv/1tMUjTSTKw5Ku0u4V5njdu/0lNr6dlwteRmCEpZNY168ewqmJ/ClBtFuQsYiTm79j6wh/TEo4VltRK03gVd1Zl0YzlenAUHrDSGdENbYO3MKHllU1g0Jat6 SJxSgkVSGmREj+rtBq12gm/+pa983EeYhUdUa8RPcrkQpQjtefk+xHs6MekDegHxGadfFwQjj wJQ3rtPKiKm9XD1EV10ru37UzqISd+n2qgdsM56z6z6QVGhjj7 +x4Tq7XOzK/lTi/dOwB+0jwukjVIzkZgP5CctEixT/qVFSD1eizqniQJ/v9KLhJeC+7giEEqM1fx6pF0x0wejbRyxlP1+YhyP2PFEGmMG/I+YJvB/4GJ2kRvaq4tnO/65+skmWriwN0Ao0sz/tya0lXY3Akynm3SnvLlUvrQJidIDdAGBB+PUKKCsPeiheHnVLn GP6MXYM2h3mhff0XE/ahrSR69+m/QjP/fG61hzOZ2yESCHwU5inK08MJrIUtdB6LPi5hFSOmuiZPt82u/7FCGufY7fH3QLw9ntxM++HHviC++Hz8s7IPsbSpzlQhOkKF9qH LMHf2XU4OHXRZXM+p/PpeGw/nHxx0RlzI5Ni8jDJ8vF1X/Hc2AnGyJyLzlJDDfqsAwRrjZL12Q1PaGVzi1fJTT7zSOFgFWeE ukiJ2OQuO4sz8ckDfZz1cuoTrz4+XXAcQx9OVwv9suuFindd6B PJFJKx6ZHUSca2E1XzyDo8yVzslmr8Xh6b8dGVvavv6poWu9NT 5feFHmYkppPbBtr3Ur910pNNelAv2Unow9pm+Zs5Xuhow3ir17 27to8tgYqVXgFvNncWMaMcIgY7dK8ITsm2xBzpfJ8TPxYIBm1r 2vfNC07/pG6aVUSLdyvvSAZqaxTGeL5/1Vr+fUIu1b7rb26OqjlPz3amncuOabj4FZSmkQhu4dmm1OycuK yeYhwHI6SbXpidz77iKRUCS+WejxBVov8HBlH2OsvdUo3bMvxy DkZ88Iy8EW6bUy4VVWrTdM7dBM++BuSadY3vQLLlY0iSjUNipC y4iiXHRStKSuuDUbFcBvrTpCzGKsxYre3O5qmMHp2poGUAJme1 4su9b9vacg0XCSJDhqXXGHKB1jCRi0Zpnhi+2v+IqX6zOkILcW WL2TVXY9TZUnTo47nm87dtrNVV4xMAIW2NKSAVcPkZfAngyk86 Df1EOVT743K++XTrTyZL8L4PKrRx/P7hGjblYzeFdXtIaP1fK0dgP4Qxs7xDWvnILoydfsFKgSwfbWD GM0y3SC280Bri1w1E1GEVvFsIVQxPCuco20aQWZ3U3AacjkxsN G+r/PJNpcmMcj9vxO8ajKRbmlFYPyvn/VbKywlEThaHUFNvkXDhRuB2/6hr4kqhMhWyOnUII9VO3437Os1QlBztGDTDjcV/xbWMdtXLVDph4STP/VaTvvSHK0wjfEA4+upsVvo6HrJj1CjWAGweMJehJuLo0n/UVAyhA0i/IL2xSG/yQZn9wEibpibpRzTywAaI/+O29Sr6oFF3W6M0qnPw/auliJC2GsB3bkJNyCovE1o9peC1z3DuVmD+MEfGaj7rlGWXM5F dADq3jimZs9psXoVk0m+T/Yx0LnFRkh0pysJWxTnZJPagWBWTXjBUF4jdCym6Ey62OudgAFK SWl0gIc/zuxPJqAA1k7rr5zvdGaIaay4bENr6PG4J3O3LYPSBThMjR/deZ1ldndUSdR4wDRqkGNUW6sv8TVHjtaQOzVFQYNTayvUxwsL1 0flfuTxKTbgtufPtd/yVZybUtsU3xPArYFGw8WbH3LyNs+2dnWGU0PnuetrqDW0GIg0t fn0HVl5WVgcqyZKRHlsjWumPjyUHKI3jAgstHqVUSi2NE1BRAa nRIPlHwYYIlc1tTkCKvz0YFoefvph0woQNaXG7wqoKdEqyhlNU tI+S7FAQhXRF99vKsjTy29CyaVAnJVpAuLQWmFiv77Bl4/31Jht1e3hgkBUlvk0igjrLRKfamwG9Zge08HH3PEww3ei8ggKB 3RVflbd4uZHHUzKi4aOsgyM0T11LzMFuRIEvBk5hvJqMsCA7u3 rqzyop+4Lf/mOIbLTqDz/Mb229d6Ahgg8lhAoKOrDLfTPq6E9CCn3TdgoVcbub74ZHtWnTu BhqGlhiiwjYUnQreuJMAFIl/tMxk+HfgYCxG5ChoDgTi/zEuyv+BYjZu0VaLyUsB6B+BWt0Fk8lkcMBDjWgaxyqDFIdfAX/wXpqLdydNjBJNQFMLwNnwchQIUqIa7Y7KWVMl3RC0BHyPWrKv6 N23Aa/8FaDqN6v77KTcGwwqLNvOwNVsiENYFMOD76xFNPUSDeFBuml8q gAJJV6D2rbobzjKgpjBBE3uI5pDXn49XaRp4rt6M4rMHoo65uq sTFzbpKQefExiyDk0nR+Egkf63bM6JbLYLXYliuRt+s8kaJ0hG HX4iUnCyW3QaSjeAh8dohKr+/7xLc44Cla8+bq0/M+C/y2GbSFKLR70wQTYtTgDZO4vzzQOm/Te4pFV7V1LHIilRknwLYIGTgpjUWiiyvElEYSq00AWMrfit0x6 jJrS7d3XDto7XKTq+dTEfwqpx3cuZkZp3s9bCc9UdqbgwGWFnZ 5EMYbwO+P7GQdHPpDO+qeEssrckZlw5l3c0AfL+ljJTScPRzWG a6QO9P2+UEET0sDuWrX7ySgs0LjEwLjI3MTAuMBqAAVFOdZAZO jal/A+T9+1d3N1usVTm0ARjEF2q13J7KgUL+UG2gUjffoqhp/szcZ7TZk9ifyFTpdSJwH7UwSK/OLFvNWVa2MLZKDcmnTaPgNW5nmAwjCqZCvZBMiak8yWUnvMinu HEFnNzjQqE53W5mmbroHiPQHzBnCcPgPj4rvrbShQAAAABAAAA FAAFABCdlKM6RrYi1w==
Cheers
wks-keys giving out wrong keys
By swappyison in forum Video Streaming DownloadingReplies: 21Last Post: 6th Aug 2023, 13:03 -
wks-keys or TPD-Keys cmd.exe errors
By euphonic in forum Video Streaming DownloadingReplies: 1Last Post: 25th Jun 2023, 15:24 -
Widewine Key request problem
By Caidking in forum Video Streaming DownloadingReplies: 19Last Post: 22nd Feb 2023, 19:12 -
Playready
By hencha in forum Video Streaming DownloadingReplies: 11Last Post: 30th Jan 2023, 07:01 -
Can PlayReady be keys be acquired like Widevine?
By besweeet in forum Video Streaming DownloadingReplies: 9Last Post: 11th Jan 2023, 17:16
