Results 1 to 10 of 10
  1. I see that https://www.gyan.dev/ffmpeg/builds lists latest version of ffmpeg. Where can I get older version of ffmpeg precompiled builds? I need ffmpeg 4.3.6.
    Thank you
    Latha
    Feb 2008
    4.3.6 is a new updated release of an old branch. It was released in April 2023.
    You might have a hard time finding 4.3.6 because most of the better known compilers/distributers of precompiled binaries mainly do current branch (6.0) and don't compile updated releases of old branches.
  3. Originally Posted by ProWo View Post
    Thank you very much for the immediate reply.
    Could you please let me know where can I find FFMPEG 4.3.6 Win64 package with 4.3.6 libraries and include files?
    Earlier it was available under https://ffmpeg.zeranoe.com/builds/ which is closed now.
    Any input in this regard will be greatly appreciated
    Thank you
  4. We can get dev package upto ffmpeg 4.3.1 wayback machine, https://web.archive.org/web/20200918193155/https://ffmpeg.zeranoe.com/builds/win64/dev/ as ffmpeg.zeranoe.com/ no longer exists.
    I could get above info from below link
    https://forum.cockos.com/showthread.php?t=241818
  5. Banned
    Nov 2023
    Europe
    I tried look for it, i just found an 4.3.6 link to download some sort of tar ball, what ever that is i dont know! ill try help some more! Maybe if someone have it downloaded, the most people i now use DC++ (Direct Connect), do you use it if someone would have it on their pc?
    Feb 2024
    Germany
    Why not looking on github?
    Feb 2004
    I made a build of ffmpeg version 4.3.6.
    PB
  8. I'm a MEGA Super Moderator Baldrick's Avatar
    Added it to the ffmpeg old versions page also, https://www.videohelp.com/software/ffmpeg/old-versions
    and virustotal test https://www.virustotal.com/gui/file/00cfe5df701a59fe75d530ce1ee13550638fdd4b373eb65572...0699?nocache=1
    Feb 2004
    Thank you Baldrick.
    PB
