Use the newest beta of clever Ffmpeg-GUI.
Load your file, click main, click various, click change framerate.
It changes the videostream only.
audiostreams have to be adapted separately.
works with x264 and hevc only.
You can also try the fix timestamps option first.
this one works for the whole video.Last edited by ProWo; 9th Nov 2023 at 09:26.
Be careful. Converting VFR to CFR by that method can lead to audio and video being out of sync. Say for example you have a 2000 frame video where the first half is all 28 fps, and the second half is all 30 fps. The first 1000 frames will play for ~35.7 seconds (1000/28), the second half will follow for 33.3 seconds (1000/30). If you convert to an average of 29 fps the first 1000 frames will play in ~34.5 seconds (1000/29). Then the second half of the video will play for another 34.5 seconds (1000/29). So even though both videos play for the same total time, and the audio is in sync at the start and end, the audio will be out of sync by a about 1.2 seconds in the middle.
No, @rgr, there is still the probability that motion is not consistent with the original. Iow, depending on the type of motion in the scene or camera, there can be added jerkiness. That is what @jagabo referred to.
Scott -
Avidemux journal contains the frame duration histogram: https://avidemux.org/smif/index.php?topic=19536.0
If the video is detected as VFR because of jitter/rounding error, it is safe to convert to CFR and indeed Avidemux does this automatically when remuxing.
Anything else is inherently risky, though it might still work.
How can i convert vfr to cfr with ShutterEncoder? (or handbrake?)
By Lemenus in forum Video ConversionReplies: 8Last Post: 22nd Oct 2023, 09:20 -
ffmpeg VFR to CFR in stream copy is possible?
By marcorocchini in forum Newbie / General discussionsReplies: 1Last Post: 4th Dec 2021, 17:13 -
VFR vs CFR
By rblu in forum Newbie / General discussionsReplies: 2Last Post: 16th Feb 2021, 15:29 -
VFR to CFR conversion before editing
By droner in forum EditingReplies: 42Last Post: 15th Feb 2021, 05:01 -
VFR to CFR and Audio Sync
By videohelpuser in forum Video ConversionReplies: 3Last Post: 23rd Dec 2019, 11:46
