Results 1 to 10 of 10
  1. When using VirtualDub 2 on 4 core Intel i5 cpu i see it uses all cores when playing video, i am planning an upgrade and want to know how many cores max can VirtualDub 2 support will it utilize 12 cores?
    Mar 2008
    I think it comes down to the encoder which has its own thread management
    May 2005
    Australia-PAL Land
    Let me know how you can tell the number of cores being used and I'll check my system.
  4. Originally Posted by Alwyn View Post
    Open video in VirtualDub 2 (better 8K video) and then look inside your task manager as you play the video you should see all CPU's are loaded with work to decode or only few cores are loaded.
    Inside Task Manager (Keyboard Ctrl+Shift+Esc) open Performance tab, right click on graph and choose Change graph to select Logical processors
    When playing video you see each core is loaded with work as example image i show.
    Best if you make screenshot and post here.
    May 2005
    Australia-PAL Land
    Here you go (i7 13700K); note different GPU use. GPU 0 is the UHD 770 iGPU; GPU 1 is the RTX 3060.
    Playing a UHD video file:
    [Attachment 74792 - Click to enlarge]
    Playing a RIFE AVS file:
    [Attachment 74793 - Click to enlarge]
  6. Encoding with x264 I can get 100 percent usage of an 8 core, 16 thread CPU:
    [Attachment 74796 - Click to enlarge]
    That starts idling at 0 percent CPU usage, then the encoding starts for ~2 minutes, then back to idle.
    But I believe VirtualDub(2)'s filtering chain is still single threaded. So that can become a big bottleneck. Also, many older encoders are single threaded or poorly threaded and don't benefit much from multicore CPUs.
    May 2005
    Australia-PAL Land
    I have a bunch of Lazy cores!
    encoding that Rife AVS into x264:
    [Attachment 74797 - Click to enlarge]
  8. My point was to see the decoding / playback performance of VirtualDub itself.
    My goal was to see the decoding / playback performance of VirtualDub itself.
    Probably not using CPU so much because GPU is working, i never get GPU acceleration to work in Virtual Dub 2 how you manage to make it work?
  10. Originally Posted by Russai View Post
    My goal was to see the decoding / playback performance of VirtualDub itself...
    Keep in mind that during preview the CPU/GPU usage is only enough to display the current video at the correct frame rate. You don't expect it to maximize CPU/GPU usage. And you don't want it to maximize CPU/GPU usage.
    If you are using RIFE you are using the GPU. VirtualDub2 doesn't use the GPU for playing AviSynth scripts -- aside from displaying the picture that AviSynth gives it. AviSynth is doing most of the processing.
