Results 1 to 12 of 12
  1. Not sure what's causing this, but everytime there's something overly bright/white onscreen, the Contrast on the histogram goes wayyy into the red. When i pause or rewind the video it shows normal brightness as how it should play, but pressing play and goes back to washed out bright whites with major clipping. I tried changing my ATI AIW to a spare one i have, but still the same issue. I also use a Datavideo TBC-3000 in the chain. Not sure what's the cause, but it sure is annoying. I have to keep recapturing the bright parts like this with the Contrast dialled way down.
    I've attached an example.
    Jan 2016
    Test the equipment one at a time to identify the faulty components, How do you know which one is bad when they are all hooked up together?
  3. You must not stop, pause and rewind etc. during capturing.
    This is plain crap. Capture it again without the TBC-3000.
    How does it look when you play the tape with the player directly connected to the TV?
    Mar 2008
    Could there be some autogain mechanism at play here?
  5. Originally Posted by Sharc View Post
    I know, i don't usually. I was only doing it to show how the brightness goes normal when paused.
    I captured it again without the TBC and still having the same problem.
    I had it hooked up to my nearby plasma tv but the legacy Scart to HDMI port has stopped working so i've no way of viewing it on a tv now.
    I'm not sure what that is, but i do have everything hooked up to a UPS unit.
    May 2005
    PAL User
    It looks to me like the titles and the last head-only shots are much brighter than the single full-bird shot, then join together.
    If it's only this part of the tape, I'd try doing two captures, one for the titles and head shots with lower brightness and contrast levels, and one with the full-bird shot at higher levels.
    That grey edge on the left is a bit of a worry too.
    Can you use a (yellow) Composite cable ie AV In?
  7. Is it a commercial macrovision protected tape?
    Can you play it when you connect the VHS player to the TV as originally intended? Does your Plasma TV have a HDMI port only? No Composite or RGB or component input?
    Sep 2022
    Bavaria
    I think it is a combination of the tape, the player and the capture card that are responsible for the behavior.
    I would try a different playback device. Ideally a video recorder built before 1998.
    Here is a comparison of various PAL video recorders with similar behavior on one of my tapes.
  9. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    The capture card is always a ATI AIW, right? Which model?
    Sep 2022
    Bavaria
    No. It's the Canopus NX.
    I've used my comparision from here:
    https://www.digitalfaq.com/forum/video-capture/10658-luminance-clipping-capture.html
  11. Captures & Restoration lollo's Avatar
    Jul 2018
    Italy
    Thanks, Bogilein, I remember that thread, but also remember you had some nice comparison between ATI AIW and other cards, and is inside this same topic. Excellent reference!
