I'm thinking about buying a Sony HT-A7000 + Sony SA-SW5 + Sony SA-RS3S.
And I just wanted to know whether the setup I envision should work.
I wanted to connect the Sony HT-A7000 to the HDMI output of either my NVIDIA RTX 4080 or my Intel A380 for the audio.
My monitors are connected via DisplayPort.
Should this work or would I be required to use the HDMI output of the soundbar to get video&audio?
(I suspect this should work, but since I haven't used a soundbar and usually use a headset at my pc I wanted to be sure.)
Cu Selur
works
users currently on my ignore list: deadrats, Stears555, marcorocchini -
I connected the soundbar to my Intel card and passed it through to the second HDMI on one of my monitors.
The passing through is only needed during setup and when you want to configure the soundbar.
So I still use the DP connections for viewing and only switch one monitor to the HDMI input in case I need to change setup (run speaker adjustments,..) of the soundbar.
Cu Selur
Ps.: haven't tested whether I could also use my onboard AMD HDMI connector, but I expect that would also work. (I usually only connect stuff to it to test VCE stuff, which is normally so underwhelming that usuallynothing is connected to it)users currently on my ignore list: deadrats, Stears555, marcorocchini -
For me biggest question mark is audio synchronization with video - having so many asynchronous sources (multiplied by driver issues) may lead to this problem and if your soundbar/AV receiver is unable to propose latency compensation (can be difficult if not impossible if video advance audio) then you end with very annoying setup (or in other words - it would be easier if you can provide audio and video data at same physical source).
Sync seems fine so far.
why my pc would not show any display, if hdmi is connected to tv on off
By jraju in forum Newbie / General discussionsReplies: 55Last Post: 14th Mar 2021, 07:54 -
Why I am getting There is no device connected in a pendrive connected to
By jraju in forum Newbie / General discussionsReplies: 17Last Post: 5th Feb 2021, 18:38 -
Shogon 7 from Atomos problem with more than two cameras connected
By pwn in forum Newbie / General discussionsReplies: 2Last Post: 23rd Oct 2020, 08:21 -
Help please!! How to power my external HDD connected to TV
By thegeeman in forum Newbie / General discussionsReplies: 27Last Post: 7th Jul 2020, 12:12 -
Syncing Video from Chrome/Firefox to HDMI-connected PC
By vid00d in forum ComputerReplies: 0Last Post: 1st Jul 2020, 19:16
