I use VirtualDub to convert MOV/MP4 to Uncompressed AVI for an old video screen display software that is very, very picky about what it can use file format wise. VirtualDub is the only thing I've found that does it. However, I've noticed its randomly inserting 1-2 black frames in the start of the converted file, which is not usable at all. Ideas how to fix, or alternative program? For settings I use Full Processing with Uncompressed AVI.
I've tried Handbrake and Adobe CC for conversions, hasn't worked.
	Do you use MSU deinterlacer by chance? If you are clipping subclips to convert and save, select IN and OUT, then move to the point slightly before than IN point and play several frames until your IN point to "reset" buffers in whatever plugin stores them. I noticed this too, but it does not bother me much, as I use these subclips in Vegas to create a bigger video, so I just trim them off in Vegas.
 Really, this is a bug, but I think VDub2 developer has not updated it for a couple of years already.
  Adding black bars to videos without re-encoding?By rowjekto in forum Newbie / General discussionsReplies: 2Last Post: 19th Jul 2022, 16:09
  Keep Getting Black Frames During Encoding In FlowFramesBy Slam2343 in forum Video ConversionReplies: 1Last Post: 9th May 2022, 02:29
  Twixtor, adding frames and Vegas Pro 19By magnu in forum RestorationReplies: 5Last Post: 21st Apr 2022, 03:08
  Adding solid black frames with avisynth?By killerteengohan in forum RestorationReplies: 21Last Post: 28th Aug 2020, 09:33
  Automatically remove black frames?By nexus_013 in forum Newbie / General discussionsReplies: 12Last Post: 10th Jul 2019, 14:23
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
